Computer works fine untill you let the battery die while powering the computer. When restarted with AC power, the computer will not work properly. Will restart but it will not open any programs. This has happened before and we have to use disk to start all over with this computer. Obviously, we lose everything in this process and it is getting old. Help
    Master:
    Sergeant:
  • 381 Answers
Is this laptop or pc?
you will have a power surge problem
or the dcjack (power connector) on the laptop is faulty
Posted on Oct 16, 2010
RESTART LG COMPUTER
I have the same problem, but no solution. have you tried a new power cord?
Nov 01, 2012 | LG X110 series (610074350750)
When i charge my acer aspire the power button flashes
The DC jack in the laptop is showing early signs of intermittent issues, the jack is solded to the motherboard which sometimes breaks free over time, this is something that will eventually need to be addressed.
Mar 25, 2012 | Acer Aspire 5336-2283 Notebook
I dont remember power on password for hp nc4400
The power-on password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to Computer Setup. To clear the
passwords, you must remove all power from the system board. If you do not know the
passwords, use the following procedure to clear the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE BATTERY!
6. Restart the computer. During Power-On Self Test (POST), a ? 162 System Options
not set? message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
12.It should work....
Apr 08, 2011 | HP Compaq nc4400 Notebook
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
Pavilion dv9308nr PC Notebook: hp dv9308nr wont power on all the time... works if...
Due to regular use of the notebook, some static charges tend to stay in the computer, and sometimes results in not allowing the computer to function properly.
Please follow the power drain procedure to confirm the same:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30seconds to 1 minute.
4. Put the Battery in.
5. Reconnect the AC adapter.
6. Turn on the Notebook power.
7. Restart the Notebook.
If the Notebook boots up you may fix the battery back. Try restarting the computer only with the AC power, without the battery & vice-versa. If the issue still persists then I request you to reset the memory modules, as sometimes the memory module connection get loose.
May 17, 2010 | HP Pavilion dv9308nr Notebook
Hi forum, I have been using Compaq N610c notebook and was working fine but was not power ON . on AC adapter but it was working on Battery. From last day, the battery become zero showing battery indicator...
It's possible that the AC adapter "died", and then your computer ran on battery-power until the battery went to 0%.
Or, the socket on the laptop where the AC adapter connects could have broken, or become disconnected from the motherboard, such that the power from the AC adapter was not being accepted, meaning that your computer was running on battery-power.
Take the AC adapter and the computer to a qualified technician, who can test that the AC adapter is working fine, and can disassemble the laptop, to inspect that socket where it connects.
Mar 03, 2010 | Compaq Evo N610C Notebook
I own an HP Pavilion tx2110us, yesterday the laptop was working fine, i sent it to sleep and went to bed, today at the office, the computer simply doesn't start up, it powers up for about less than 1...
Remove AC power and then the battery. Then just plug in the battery itself (no AC). See if the laptop will power up. If it does plug AC power back in and don't use the sleep mode as there are problems with some Microsoft updates stopping the computers from resuming from sleep.
Please let me know how you get on.
Good luck.
Feb 22, 2010 | HP Pavilion TX2110US PC Notebook
Dell xps m1210 won't power up with new battery. Check notes.
If it is working fine with a fresh battery then it is not a motherboard problem. It is either a bad ac adapter jack on the motherboard or the actual ac adapter cord is not working. Try cables2go.com as they have replacement ac adapters for almost everything under the sun. Hope this helps.
Jul 10, 2009 | Computers & Internet
Dell 710M laptop won't work with battery
hi thanks for using fixya!
If your laptop is working exclusively on AC power and battery is seems to be useless, I suggest that you purchase a new battery for your laptop.
If you need further assistance, let me know
Apr 27, 2009 | Dell Inspiron 710m Notebook
Fan Died on my Gateway MT-6707
fans can die without any reason that's possible and because of that your laptop is shutting down due to overheating because the processor isn't being cooled so you may need a new fan (but test the pin if there is any voltage there). it could be the motherboard not giving any power to it.
you may also have a problem with the DC socket not charging your laptop thats easy to test, plug the charger into the laptop with the battery and without switching it see if there is an amber light that shows the ac is fine.
Mar 02, 2009 | Gateway MT6707 Notebook PC
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
