Question about Canon BJC 80 InkJet Printer
I have a bcj-80 printer that has been sitting in the closet for three or four years. I got it out and plugged it in and its dead. Is there a fuse, perhaps, that needs to be replaced?
    Master:
    Sergeant:
  • 381 Answers
Yes try that first
Posted on Oct 16, 2010
I have a 04 volvo s 80 I have gas on all the spark plugs and won't start why
Takes three things to make engine run gas,air, and compression. Plug code reader in get codes ..
Nov 20, 2014 | 2004 Volvo S80
Sanyo DP26640 has no power at all. It worked well for a little over a year and was plugged in with a playstation in the same outlet. No problems with the playstation. Wondering if buying a power boar
If there's no sign of life at all, the power supply is probably dead. It may be something as simple as a blown fuse but not all of those are replaceable. If you're comfortable around electronics, you could open it up, check the fuses (there are usually two or three), and replace the bad one (probably the main power fuse) if you find one. If you're not comfortable around electronics, or can't find a bad fuse, you should try to find a TV repair shop if they even exist anymore.
Hope this is helpful! Good Luck!
Nov 18, 2014 | Sanyo Televison & Video
I have Yamaha RX-V800RDS
After sitting that long the capacitors in the power supply can dry out and become inoperable. The first thing to check is to see if the power supply inside the stereo is working.
Jan 14, 2014 | Audio Players & Recorders
How do I remove the back bumper from a 2006 hyundai tuscon?
take help of the following steps to remove rear bumper on ur tucson.
Open the trunk of your vehicle.
  1. Unscrew all the screws on the inside plastic trim that covers your bumper to trunk connection.
  2. Pry the plastic piece out with a flathead screwdriver. You will expose the bolts that attach the rear bumper to the trunk.
  3. Unscrew the bolts connecting to the inside of your rear bumper. There should be four bolts.
  4. Unscrew the two to four screws connecting to your bumper from the inside of the rear wheel tire wells. These screws are on the area of the tire well that is closet to the bumper.
  5. Slide under the rear of your car. Use a flathead screwdriver to pop the plastic rivets out of place along the underside of the rear bumper. There should be four to six rivets.
  6. Squat behind your car and firmly pull the bumper off. There will popping plastic sounds, this is the pop-in-place plastic rivets that are the last pieces that hold your rear bumper in place.
Dec 27, 2010 | 2005 Hyundai Tucson
F20 Error for Kenmore HE3 Gas Dryer
make sure your vent for the dryer isn't starting to get clogged or it may have a hole in it therefore hot moist air is getting in the closet instead of outdise
Sep 07, 2009 | Dryers
Canon bcj-80 prints blank pages
The problem comes mostly from the printhead. It helps to put a drop of water on the cleaning pad over to the right where the printhead parks, before doing a clean cycle.
Jul 01, 2009 | Canon BJC 80 InkJet Printer
My bjc-80 wont print after sitting for several months. the only change was a usb connector to my new dell fresh cartridges.
  1. Make sure printer is turned on.
  2. Press and hold the RESUME button for at least two seconds until the printer beeps twice.
  3. The POWER light will blink for several seconds while the print head is being cleaned.
If three print head cleanings do not correct the issue, you may need to replace the BC ink cartridge.
Oct 06, 2008 | Canon BJC 80 InkJet Printer
Dead tv
If this set has been sitting in storage this long theres no telling what could be wrong . Take set to a repair shop.ThankYou for trying FixYa. Have a Nice Day.
Feb 19, 2008 | Televison & Video
WON'T CHARGE OR POWER ON
Your going to need to wall outlet, when the player is completely discharged it is impossible to charge via the usb.
Aug 15, 2007 | Toshiba Gigabeat S30 MP3 Player
Canon BJC 80 InkJet Printer Logo
65 people viewed this question
old marine
old marine
