Question about Kodak ESP 5 Printer
Printer isnt printing the color yellow.changed the ink and still the same thing..is it the printerhead?
    Master:
    Sergeant:
  • 381 Answers
Is the yellow ink seated properly?
have u carried out the maintainence of the print head using the recommended guidance?
Posted on Oct 16, 2010
  • cabletechie Oct 16, 2010
    yeah, did the maint. on it. also the printhead cleaner...ink is seated
  • Ikhlaq Hussain Oct 16, 2010
    please send the exact model no of the printer
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Yellow ink isnt printing even after deep clean and test page print
Maybe the ink inside the catridge already low or empty, sometimes each color ink will empty at different time, depend on usage. Fill only the yellow ink and try to print again.
Hope this help and RATE please !
Jan 18, 2011 | Canon BubleJet i965 InkJet Printer
Installed new blk ink cart and others are all o.k. Will not print black at all - if I use the color button or try to print from the computer in color, words come out very light and other colors are not...
I assume that you inserted an new OEM black cartridge. If you are using aftermarket of refilled cartidges, change to an OEM cartridge.
- Press on the printer
- Press of and select
- Press of to choose , or
- Press
- The machine cleans the printerhead and goes back to the Ready screen when finished.
If you clean the head 5 times and things don't improve, the printer should be serviced at a printer service center.
If you are using aftermarket or refilled cartridges the ink is typically not up to manufacter specifications and can gum up the printheads.
Oct 04, 2010 | Brother Office Equipment & Supplies
Black ink does not print
If your printer have a separate printerhead with the cartridge just try to replace the printerhead of that printer it is because the printerhead have a problem on that.
May 28, 2010 | Brother MFC 240C All-In-One InkJet Printer
Will not print---all I get is a blank paper
Try to check the ink of your printer that they have more ink inside. Or els just check the printerhead of that printer its maybe that was a problem for that. If they could not print at all after this solution just change your printerhead it is because that was the problem. If your printer are using the built-in printerheat from the cartridge just replace the cartridge of what color are did not print but if your using separate printerhead of your cartridge just only replace the printerhead only.
May 27, 2010 | Dell 926 All-In-One InkJet Printer
My Printer isn't printing the correct colors. My photos look like an old Polaroid picture with a washed out greeny/yellow color to them?!?! I bought staples brand ink which said it was compatible with my...
Try this take an old empty cartridge and mix some ink cleaning fluid into each of the tanks. Now take some alcohol and a Q--tip and wipe the heads on the contacts where the cartridge comes in contact with the printer head.
There are three contacts that control color and one that controls the black . Clean with the alcohol, wipe with a Kleenex or a dry q-tip lightly. Now lightly shake the used printerhead to mix the cleaner into the residual ink that remains in the Printer cartridge. Now once the the cartridge has bee reinstalled in your printer go through a printerhead cleaning and head alignment evolution. Instructions for this should be in your printer manual which is a drop down program on the Printer Program Main File Icon. Some printers will automatically set up this program on the screen in easy to follow steps. If this doesn't work its time to get a new printer , add it to your Christmas list.
Nov 09, 2017 | Canon MP610 Photo All-In-One Printer
PRINTER IS NOT PRINTING COLOR COPIES ANYMORE. INK WELLS FILLED
please check in the printer properties if the print in greyscale option is turned on
Mar 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
Epson CX7800 print head not working
it would be better if you get a new printer or the best to use is vodk and leave it over night to get rid of all the dryed ink
Aug 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
New printhead will only print 3eBK, no color
If you're concerned with a clogged printhead try to clean it with acetone solution. Also, check the cable connections to your printerheads they might be loosened..
Feb 23, 2008 | Canon i860 InkJet Photo Printer
Doesn't print correctly
print a page of solid colour..but donot print the entired page..maybe a third without wasting ink.
these printers are pigs when it comes to their printerhead
Nov 10, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Kodak ESP 5 Printer Logo
236 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
