Question about ASUS Computers & Internet
Has the hard drive a connector befor installing it in the bay
  • tedkelly Oct 16, 2010
    is there a caddy for the hard drive
    is a caddy used for the hard drive on the ergo ensis L4000L
    Master:
    Sergeant:
  • 381 Answers
Its most likely a sata hard drive, which wont have any kind of connector and you can just slot the hard drive in
Posted on Oct 16, 2010
Testimonial: "good advice but i new that i shoud have asked is there a caddy for the hard drive. a very good place for ansers"
Dell inspiron 3847
Dell has not published the procedures for installing an additional SATA hard drive, the Inspiron 3847 has a second 3.5" bay, for the second hard drive next to the primary hard drive, there should be a set of rails located in the bay, two 6-32X1/4, phillips head screws are needed, to attach the rails.
The procedures on pages 26 to 28 of the owners manual should give you an idea of what is required for the installation.
http://ftp.dell.com/Manuals/all-products-Infodev/esuprt_desktop/esuprt_inspiron_desktop/inspiron-3847-desktop_Owner%27s%20Manual_en-us.pdf
You will need a SATA data cable there should be a spare SATA power connector inside the case.
After installing the drive enter the system setup and check that the hard drive is 'enabled' [on] and recognized.
For Windows to recognize the second hard drive, it must be partitioned and formatted.
Go to Control Panel, Administrative Tools, Computer Management, Storage, Disk Management, right click new drive, select format, then you can assign a drive letter.
May 08, 2014 | Dell Computers & Internet
How to slave the hard drive
You must go to BIOS setup and follow the steps.God bless youHowever follow this steps:
Instructions
Remove the screws on your computer case and slide the cover off of the machine. Notice the hard drive bays in the front of the machine. The existing hard drive is installed in one of these bays.
Use the tweezers to set the jumper pins to "Slave" mode. The jumper pins are white connectors located on the back of the hard drive. Above the jumper pin section on the hard drive is the schema to set the drive to "Slave."
Insert the hard drive into the computer case bay underneath the existing drive. Screw in the drive and mount it to the case using the screws included with the hard drive packaging.
Connect the hard drive cable from the main hard drive to the secondary slave drive. There are two connectors on the hard drive cable. The very end of it is inserted into the main hard drive. The middle connection is used for the slave drive. Insert this secondary, middle connector into your newly installed drive.
5
Insert one of the power supply cables into the back of the hard drive. This supplies electrical power to the device.
6
Replace the case cover back onto the machine. Ensure you replace the screws to properly fasten it to the computer case.
Jan 23, 2013 | HEWLETT-PACKARD 500B MT E5700 3202GB 27 PC...
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I want to replace HDD on my HP ProBook 4510sand I don't know how help somone.
Hard Disk Drive removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data. CAUTION: Observe all precautions when removing and replacing components.
  2. Remove the battery, switch cover, keyboard, and palm rest.
  3. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  4. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
  1. 1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the system board connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Sep 19, 2010 | HP ProBook 4510s FM849UT Notebook
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
What hardrive for my armada M700?
Hard Drive Installation Instructions 40 gig IDE DRIVE
  1. Shut down the computer and remove Battery Pack and AC adapter.
  2. Locate Hard Drive compartment on the front panel, just left of the head phone jack.
  3. Turn Notebook upside down.
  4. Remove the one torx screw that is securing the hard drive. (A security screwdriver was provided with the computer.)
  5. Push down on the hard drive bezel on the front of the hard drive.
  6. Lift the bezel up 90 degrees to create a handle. Pull the hard drive out of the hard drive bay.
  7. Remove the 4 black screws at each corner and lift off the black tray.
  8. Gently remove the silver bracket and connector.
  9. Place connector on new hard drive.
  10. Place the black tray on the HDD. When looking at the hard drive with the label up, the black bezel goes along the left side of the hard drive.
  11. Replace the 4 black screws from step 7.
  12. With the hard drive bezel pulled down, slide the hard drive into the hard drive bay.
  13. Push up on the hard drive bezel to secure the hard drive in the bay.
  14. Secure the hard drive bay by replacing the screw from step 4.
  15. Replace the battery pack and all cables
Aug 08, 2009 | Compaq Armada M700 Notebook
Drivelock hdd bay password
Hi
This drive may have been used before and may have had a password set on it. If it is new take it back and exchange it
Cheers
David
Jun 21, 2009 | Western Digital Scorpio 160GB Internal...
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Mike
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Sata drive will not fit
This is clear that your laptop doesnt support SATA and will support only to the previously used type of HDD..
Thankyou
Jun 17, 2008 | HP Pavilion dv9000z Notebook
I want to replace the hard drive. I have the new hard drive but I am unsure how to procede
The 13 Easy Steps to Installing a Primary Hard Drive Compiled By Our Editors Believe it or not, all it takes is less than a half-an-hour and a Phillips screwdriver to install your primary IDE hard drive into your desktop PC. Simply follow this illustrated 13-step guide and it’s mission accomplished! Please make sure you consult your user manual and other manufacturer-provided documentation while you complete the installation - you will need to refer to instructions at certain points in the operation.
image1.jpg 1. The first step is obvious! Power down your PC! And for safety measures make sure you have unplugged all your power cords.
image2.jpg 2. Next locate all the screws and/or clamps that hold the computer case and/or panels together.. image3.jpg 3. Now it's time to gain access to the interior of the computer case. Simply remove the case or the panels that hold it together.
image4.jpg 4. If your PC happens to have a removable hard drive bracket, now is the time to remove it! It’s specially designed to be removed without hassles, and its absence will make this simple installation project even easier.
image5.jpg 5. Now it's time to leaf through the documentation that came with your hard drive, along with any included diagrams, for instructions on how to set the jumpers on the drive. If you're the type of person who hates to read the instructions, bury your impulse to neglect this crucial step. If your system has but a single drive connected to the cable, use the “Cable Select” option; this will suffice in most cases when there is only one drive. If another drive exists it will be connected to the same IDE cable, using the “Master” setting.
image6.jpg 6. You're almost halfway done! Wasn't that easy. Now the fun begins! Slide your hard drive into the drive bay, then fasten it down. Some cases employ a system in which slide rails mount onto the drive for easy insertion and removal from the drive bay.
image7.jpg 7. Remember that removable drive bay bracket that you removed in Step 4? Now it's time to return it to the inside of the case.
image8.jpg 8. You will find that most ATA/66 and ATA/100 IDE cables have either a blue connector or a connector labeled “System Board.” In the likely case that this applies to your PC, plug this blue connector into either the IDE0 (Primary) or IDE1 (Secondary) connector on the motherboard. The primary connector is color-coded blue, in most circumstances, to indicate that it should be used for a hard drive. Usually, you can insert the cables in but one way. However, if the cable is not keyed for one-way insertion, make sure that the red stripe on the IDE cable matches up to “Pin 1” on the motherboard.
image9.jpg 9. Attach your connector that is located the farthest distance on the ribbon cable to the hard drive. Usually this connector is either black or labeled “Primary.” Make sure you place the red stripe on the cable at pin 1 of the hard drive’s connector. Note: Most drives are keyed to allow the cable to fit in only one specific way.
image10.jpg 10. Now locate a 4-pin power connector from the power supply. Simply attach it to the hard drive’s power connector. You're almost done!
image11.jpg 11. Next, replace your computer case or panel.
image12.jpg 12. Tighten any screws or clamps to fasten down the case or panel.
image13.jpg 13. Finally, reattach your computer’s power supplies.
Voila! You’re done. Your hard drive should now be installed and ready for operation. Now your computer BIOS must detect the hard drive the next time you power up your PC. Double-check your PC or motherboard user manual for instructions on how to detect a new hard drive. Perhaps you may need to change some of the parameters in BIOS to detect the hard drive on the controller. You must also format the drive before it can be used with the operating system. Again, consult your manufacturer-supplied documentation for additional information.
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
