Question about LG RC185 DVD Recorder/VCR
I have a LG VHS/DVD combo. I can transfer the content of a VHS to DVD and it plays back perfectly on the sane unit. However the DVD is not recognized on any other DVD player or computer. How can I solve the problem? Thanks..
  • ninolevy Oct 16, 2010
    Yes. Thanks!
  • 10,594 Answers
After finishing recording on dvd disc, make sure to finalize it in same recorder then all other dvd players/ dvd roms will recognize it as valid dvd disc and start playback.
Finalize option would be available in VHS/DVD combo menu.
Thanks.
Posted on Oct 16, 2010
  • Daniel Martinez
    Daniel Martinez Sep 23, 2011
    The manual shows you how to get to the screen that can change the format that the machine will record. one format will ONLY read or playback on the original machine. The other format can be read or played on other machines.. READ THE MANUAL...
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
LG DC593W - DVD & VHS Combo
hmmm..ok...sounds like a video setting issue on the way in..you'll need to go to the menu, and reset the input settings, so it's in alignment...
May 27, 2008 | LG DR-4810 DVD Recorder
Lg dvd recorder/vhs combo doesn't read dvds
Buy a DVD cleaning kit follow the instructions, sometimes brings it back to life. If no change! the assembly will need to be replaced,"not cost effective" cheaper to replace.
Mar 15, 2012 | LG XBR446 DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
LG RC6821W combo
Did you finalize the disc when you finished.You normaly have to do this for it to play on another machine,hope this helps
Jan 31, 2009 | Televison & Video
LG V8824W combo DVD VHS player
LG V8824W combo DVD VHS player can I copy VHS to DVD?
Oct 20, 2008 | LG Televison & Video
Sanyo DMW-3800 system problem
call jinnie at sanyo
ph # is 870-633-5030
for the 9 pin cord from unit to subwoofer
Dec 20, 2007 | Sanyo DWM-3800 System
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
LG RC185 DVD Recorder/VCR Logo
349 people viewed this question
