Question about Bladez Ion 9.9 Fold-up Treadmill
Just turned on my treadmill after a long period of time. I have power ( the console lights up) but none of the buttons are working, do you know what the problem could be?
DC-6 error on Lifespan Treadmill
Follow attached link to see user manual.
Unplug treadmill.
On page 13 of the users manual, read step 5 part B regarding the wiring harness. Unplug and plug back in each of the connectors of the wiring harness. Plug the treadmill back in to see if it now works. https://s3.amazonaws.com/lifespanfitness/pdf/Manual_TR4000i.pdf
Jul 30, 2014 | Lifespan Fitness TR4000i Folding Treadmill
CONSOLE HAS NOT LIGHTS
Can you change the illumination setting like in a car? The lights are most likely LEDs which dont just burn out. and are independent.
Apr 05, 2014 | Exercise & Fitness
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
None of the touch buttons work. Fans, volume, speed, incline etc etc. The only two buttons that work are incline buttons 6 & 7. Power comes on and key turns on and off though. Can anyone advise??
sorry but i dont have a solution for you!! i bought the t9ci back in nov of 2008, like you none of the buttons worked had to wait till march of 09 for nordictrack to send me a reprogram card, which did not fix the problem. i then recieved a new console, in april 09, which stopped working in feb 10. a service tech came out and had no clue, so the sent another new console which did not work. in march 10 they sent a whole brand new treadmill, and when i got on it last week the console was not working once again!!!!!!!!!!!!! i hope you dont have as many problems as i did
Nov 05, 2011 | Nordic Track NordicTrack T9 ci Treadmill
I need to know where the batteries go
Dear Sir: I will help you, please do the following step: Instructions Things You'll Need
  • Power supply
  • Standard screwdriver
  • Batteries
  • Access to local fuse or circuit breakers, if necessary
    • 1 Check to see if the Pro-Form device is properly plugged into a working, grounded power supply if none of the console buttons are working. Turn the device on and reset local fuses or circuit breakers if necessary; reset the circuit breaker switch on the base of the unit.
    • 2 Turn off the fitness device and unplug from the power supply if the console only shows zeros or the console buttons are not working. Use a standard screwdriver to open the battery compartment on the underside of the console. Pull out the old batteries and recycle, if possible. Replace with new batteries, using the old batteries as a guide for the size and type of batteries needed. Place the flat end of each battery against the spring inside the battery compartment and gently push the battery into place. Close the battery compartment and restore power.
    • 3 Press and hold the "Stop" button if the console is only flashing repeatedly, indicating that the device is in demo mode. Insert the console key and push the "Speed Down" button to turn off the demo mode on the unit. Remove the console key.
    • 4 Reset the console buttons if the incline is not working properly on the machine. Insert the console key and press one of the "Incline" buttons. While the incline is in the process of changing, remove the console key. Wait two or three seconds and re-insert the console key.
    • 5 Remove the console key and unplug the Pro-Form device if none of the above steps are resolving the problem with the console keys. Unscrew the three screws that hold the motor hood on the front of the device and pivot the hood off the machine. Find the magnet and small reed switch on the left side of the pulley. Turn the pulley until the magnet is aligned with the reed switch and the gap between the two is approximately 1/8 inch. Reattach the hood, screw into place and turn the treadmill back on
If you need further assistance, please reach me.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Oct 16, 2011 | Proform XP Weight Loss 620 Treadmill
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not...
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Jan 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
  • For questions about parts, service, user's manuals or non-working products, please call our NordicTrack Customer Service Department at 1-877-993-7999.
  • For questions about parts, service, user's manuals or non-working products, if you purchased your equipment at Sears, please call our NordicTrack Sears Customer Service Department at 1-888-825-2588.
Apr 21, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
I have a NordicTrack A2250, about 2 years old. When it's turned on, the control panel lights up, and when I insert a program chip, the console "speaks". However, the neither the incline nor the belt...
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
Dec 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
Bladez Ion 9.9 Fold-up Treadmill Logo
21 people viewed this question
Top Bladez Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
qa1012
Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
