Question about Microsoft Xbox 360 Console
WATS WRONG WITH MY CONSOLES?
I HAVE 2 360'S 1 HAVE 3 RINGS &THE OTHER 1 HAVES 4
    Sergeant:
    Champion:
  • 285 Answers
Depending on the Age of your 360 , the one with the 3 Rings ; or as known in the trade as 3 RROD, microsoft supplied it with an extra 3 year warranty ontop of the date it was purchased but this fault is common and its down to an overheating issue on the xbox's that when the boards reach high operating temperatures and cool down again constantly , the board is contracting and expanding thus , loosening the pins of the CPU and or GPU chips
and the one that has 4 red lights is indicating either your AV Cable isnt connected properly or has developed a fault , or the GPU Chip inside the console has become faulty due
hope this helps
Posted on Jun 03, 2008
Wats d gap in rings and n how many kms does the engine has to run
A general rule of thumb for ring gap is .003 " per 1" of bore. Example 4" bore minimum gap at bottom of cylinder for the ring is .012". IF fitting new rings then push the ring to the bottom of the bore ( smallest dia.) and measure the gap . nothing under .010". Max ring gap at this point should not exceed m.025" and if the gap exceeds this then the sides of the rings will have sharp edges from wearing on the piston lands.. The distance travelled depends on the service interval and the air cleaner being used as a dusted motor will need new rings within 15.000miles. and a well serviced motor can exceed 150.000miles before the rings need replacing
Apr 21, 2014 | Cars & Trucks
Carban fouling
carbon on the plugs is a sign of running too rich (Choke on blocked air filter)). When mixed with oil it can be the sump fumes are excessive indication worn rings. If a 2 stroke it is a wrong fuel/oil mixture. Reduce by running hotter plugs (See plug chart at you spares shop for hotter number plugs)
Jun 22, 2013 | Cars & Trucks
Xbox is coming up with an error screen and has a red ring instead of a green one on the power button
2 red rings is over heated 3 is harware fail 4 is missing power and 1 is the hardest to fix for exact error code turn on hold controller connect and press eject 4 is for 0 1 is for 1 and so on remember the code and look it up it will tell you the problem most likely red rings of death so send it to microsoft call at 1-800-4my-xbox or look up a guide or buy one off ebay there cheap and easy
Dec 04, 2010 | Video Game Consoles & Games
Kids got wii 4 gift from dad it worked fine was plying games on it wii sports came with it haves 5 or 6 games on 1 disc all could play up till not long ago kids not played on it for a little while but...
the Nintendo wii is a glorified dvd player with a few major exceptions. it sounds like the units optical pickup has dust or debris on it. try the
Wii Lens Cleaning Kit at amazon for 10 bucks. very common and simple fix.
http://www.amazon.com/Wii-Lens-Cleaning-Kit-Nintendo/dp/B001GZT1UI
Aug 12, 2010 | Video Game Consoles & Games
When i play xboxlive it will freez then the screen will be green or red then i have to turn my xbox help
If this is what happens each time you use your your console, it might be broken. Does it have any red rings around the console's display? If that's the case, check out these links by Microsoft corresponding to the amount of red rings on your console:
1 red ring
2 red rings
3 red rings
4 red rings
They extended the warranty to three years from the purchase date for the three rings. Give them a call at 1-800-4MYXBOX and see if they can't help solve your problem. Hopefully you're still under warranty. Good Luck!
Jan 08, 2010 | Microsoft Xbox 360 Console
It always haves four red rings
4 red rings is a problem with your AV cable its either faulty or damaged try removing it and see if the lights go away altho sometimes if there is no av cable it still dispalys 4 red lights, if that doesnt work its the ANA chip has died or has lifted off the board
Nov 05, 2009 | Microsoft Xbox 360 Console
Hay me again
to enable your upnp you need to "log into your router" the all your settings will be there for you to change such as enable upnp tutorials for this can be found on youtube
Jan 27, 2009 | Sony Playstation 3 (PS3) Console
Ds no working
hey i know wats wrong ill tell you. when you have your ds for about 1 year a little piece of plastic comes off where the light is it usually makes the ds have times when it just turns itself off then on again, i reckon yours just happened differentley. I suggest you use the warranty before it expires :-)
Dec 06, 2008 | Nintendo DS Lite Console
My Xbox 360 has a flashing 1/4 of the cirlcle light a message comes up saying error (E 74) is my **** broken??`
yes all 1 800 4my x box ,they call it the rings of death ,they will repair it free of charge and send you a box to ship in in prepaid,just call and tell them the error code,I have 2 xboxxes and beleive it or not this happened 2 both of them and one is the elite,they dont bother fixxing it theyll send you a new one and a 1 month mebership free
Jul 07, 2008 | Video Game Consoles & Games
I ned heip on my xbox 360?
htgfxdsghfxzgxdrgfdczfgdcgfdgzfdgrzfdcgfdgfdzxcrfszdrgfdzcgfdFSDEFSDZFSDCFSDFSDFSDSFDDDDD
May 02, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
