My Toshiba TDP-S25 will not produce good colour. I have adjusted the colour settings but it still has very weak colours. Your help would be appreciated
  • peter797 Oct 16, 2010
    Thanks. Do you think the bulb might be the problem? peter
  • peter797 Oct 17, 2010
    yes. that was very helpful.Thank you
  • 11,800 Answers
I'm supposing that you have put the Color and the R/G/B-level settings to the max and that didn't helped.
In that case the only thing left that you can do is to alter the level of the color at the source: in the driver for the video card (if you use a pc) or the settings of whatever player it's connected to.
Posted on Oct 16, 2010
  • Azrael SRL Oct 16, 2010
    When the bulb ages the image becomes darker, but it doesn't loses it's color - it doesn't become black and white - so it can't it in your case.
Toshiba TDP-T9. the light won't change from yellow to green. we tried restarting the computer and the projector, but nothing seems to work.
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | Toshiba TDP-T9U Multimedia Projector
Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 06, 2009 | Toshiba TDP-S20U Multimedia Projector
My color is washed out and dim and the colors are wrong . Toshiba 65h83 projection hd tv
I don't know your model, therefore I will tell you genericaly what the problem may be.
There are many things that can cause this type of fault. The response of the video amplifier stages would have to be checked right up through to the output that drives the projection. it is also possible that there is a fault with the colour demodulator. If the set uses projection tubes it is possible that the tubes are weak, or there is dirt in the optics. Colour demodulation problems can also cause the colours to not be correct. Many models using tubes have an optical transparent cooling fluid in front of the tubes. This fluid may have to be changed.
Feb 23, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
Focusing
Hi real12
Unfortunately you will have get the focus ring replaced before you will be to make use of it if your model doesn't have automatic zoom and focus in the user menu.
Sorry , but there simply is no other way.
Colour
ok this problem occurs mostly due to the loose connection in the VGA cable between the pc and the projector..
try changing the cable to give any other input and see it and then confirm it... that the color sensor of the projector is weak...
Mar 10, 2008 | Office Equipment & Supplies
COLOUR MISMATCHING
befor going anywhere change vga cable between pc and projector.-and run video source from anywhere and check colour mismatch.if you got mismatch from both pc and video go to menu and make some correction to colour . if all failed you have to pass it to service center.
Jan 29, 2008 | Toshiba TDP-T90 Multimedia Projector
Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
52 people viewed this question
 Grubhead
Grubhead
