Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
Hello mate re mv450
Hello to you,
I purchase this machine about 3 months ago, its a M450 Ice Cube machine, right now i just the wall, and i need help. The problem i have is the alam light is on(triangle or the forth one) , and can't produce ice or you can say harvest take too long, i need a solution. i press reset it start normally , the machine start normally and when about 10 to 15mins during the process the light come on and no ice drop also the water not cold at all. when you look from the side of the ice machine , one of the hose at the back it all ice and the top hose is not cover with ice , has anyone have this problem before or do you have a solution . please advice. my email is hfaolotoi@yahoo.com.au many thanks henry
  • 5 more comments
  • Tiatala Jun 08, 2008
    Thanks mate, GooD news, i don't know what happen, the machine just work and produce ice, can i email you for your help if happen again, the machine is only 3months old. I also Just purchase 3 more ice machine, the three i purchase is 2 MANITOWER S800 series and S1200 SERIES (second hand), And 1 Renai model , it have two heads.
    I need to produce 500 bags of ice a day at 4kg. im planning to purchase a Ice Tube machine.
    im still hungury for more machine. there are new machine in the US on the ebay very good price at 230v at 60hz , but it does not work here cause our power take 240v at 50nz. do you have a solution. is it expensive to convert from 60 to 50hz.
    hope to hear from you the best.
    thanks
    henry
  • Tiatala Jun 09, 2008
    ok got it, Well i hit the wall again, the read light is on again, im very confuse, it was working and produce 15 bags of ice, and then suddenly no more ice, some how on the last patched of ice, the ice become thicker, so i adjust the thickness sensor, and still the same, the whole process to the point sound like about to drop ice and the light comes on and stay. even if you press reset, it the same thing, im thinking its the thickness sensor is playing up. the water all running the cycle all good except light come on at the end of the cycle and no ice plus light on. please advice me what should i do, thanks henry
    hi mate,
    just to follow up your first comment, what is the soft water , and is there anyway to test the sensor if faulty, cause its a new machine , 3 months old , im happy to chage the sensor , second how to clean this sensor, before i get a new one.
  • Tiatala Jun 10, 2008
    Mate,
    you are good, ok . if i clean the sensor, would it harm if i clean with a tooth brush, 2nd you mention i need to dry it . would this do any damaged if i put pressure on the sensor , such as tooth brush. im very happy to do it. please confirmed it. thanks champ
    Mate,
  • Tiatala Jun 16, 2008
    hello mate, we found the problem, the problem was, there was a block at the valve at the back, which the air goes into the evaborator, so we change that, now its back to normal, except the droping of ice was used to be 19 to 20 mins each batch now it take to 25min to 30min drop per batch, i even adjust the sensor, is there any other thing i forget to adjust. hope to hear from you,
    thanks henry
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    you didnt say you bought it new or used.
    if used most likely its the condensor, its either going out or defective the radiator should be free of dust and fan cleaned and moving.
    Let us know, Thanks
  • 828 Answers
Check the ice thickness sensor for mineral buildup and clean if necessary. I downloaded the service manual from a site in New Zealand. If the Ice thickness sensor is free of scale make sure you are NOT supplying the machine with soft water.
Let me know if this solves your problem. I have been servicing Scotsman Ice Machines for over 38 years in the US. I will try to assist you any way I can. This particular model is not sold in my country.
Posted on Jun 03, 2008
  • 3 more comments
  • James Helmer
    James Helmer Jun 08, 2008
    If the name plate on a unit specify(s) only 60 Hz cycles I would not apply it to a 50 Hz cycle power supply. If the name plate states 50/60 cycles it can be used on ether power supply.
  • James Helmer
    James Helmer Jun 09, 2008
    Back to the beginning. Check and clean the sensor, it should be 1/4 inch (6.33MM) from the evaporator. Replace the sensor is it does not work. Part number CM81453434.
  • James Helmer
    James Helmer Jun 10, 2008
    Clean the sensor with a tooth brush and Ice Machine cleaner. Then rinse it very good and dry it.
  • James Helmer
    In the cleaning of the sensor not very much pressure is used to do the cleaning with the tooth brush. Using hot water with the ice machine cleaner accelerates the action of the cleaner to dissolve any mineral deposits. Scraping with any metal object will scar the plastic surface giving area for buildup in the future.
  • James Helmer
    James Helmer Jun 16, 2008
    Cycle time is determined by water supply and ambient temperature. These factors will vary. Check the thickness of the bridge between the cubes. As long as the bridge thickness is within specifications you should be O.K.
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
We have a U-Line mini fridge with ice maker. 1 month old and 1 week ago it started making "working too hard" noises. 1 week ago we had paused the ice making function. Related ?
ICE CUBES IN ICE MAKER HAVE LIKLEY SHRUNK
AND ARE NOW JAMMED IN ICE MAKER INSTEAD OF FALLING OUT
CHECK THE ICE MAKER FOR JAMMED CUBE
Jul 20, 2017 | U-Line Refrigerators
My fridge produces water but no ice
Hello Catherine;
My name is Peter. I am a retired field service refrigeration technician.
You have not provided me with any information to go on. Send me your model number. The model number is located on a label, inside the fresh food section, on the side wall near the top.
Until then:
1.) Reach in and feel if your fill tube is blocked with ice. If so it needs to be cleared.
2.) Feel in your ice maker ice cube mold. Has a ice cube hung up preventing discharge?
3.) Depending on your unit, your may have a bad infra-red transmitter or receiver.
4.) You may have a bad water solenoid valve.
I need your model number to be more exact.
Jan 01, 2015 | Refrigerators
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Ice cube tray does not fill up water feeding tube is frozen.
The problem you are having is caused by water leaking past the=> MJX42111401 Water Inlet Valve Change the MJX42111401 Water Inlet Valve and this will solve the water freezing between ice harvest. On most refrigerators this part can be found on the back of refrigerator and near floor, Let me know if you have other questions, Thanks Sea Breeze
May 24, 2012 | LG LSC27910 (265 cu ft) Side by Side...
Water and Ice have tasted like **** since we got the refrigerator (about 1 year ago) I believe the soultion is bypass the storage tank, but I can't find it..
When the Ice Smells
1. Replace water filters every 6 months to avoid musty odors from getting into your ice. If you don't replace the filters, they become clogged with the chemicals they have been removing from the water. In addition to smelly ice, you may see a drop in water pressure if you have a water dispenser, and possibly a decrease in ice cube size.
2. Remove the cap from the new filter.
3. Place the cartridge inside the holder, and twist to the right.
When the ice smells...water & ice have tasted like ***** also.
Good day : )
Jun 21, 2011 | Refrigerators
Icemaker is not making ice cubes. fridge is 3 months old.
Well if your ice cube bucket is on the freezer door it self then it could be anything from the optics system to a bad icemaker to a water valve issue...if its located on the side freezer wall. the water valve could be bad or the i/m module/icemaker
Jan 22, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The scotsmand machine make ice, but quantity of the ice seems limited. The machine was descaled a month ago, no signs it needs serviced again. Could the cube sensor be faulty?
Take a can of compressed air and blow out the dust in the coil. If the coil can't get rid of the heat, it reflects in the amount of ice it produces.
Sep 15, 2010 | Scotsman Ice Machine, Cuber, 1825 lb....
Hello Where can I get the Franklyn Chef Ice
fit a universal pump from any refrigeration parts shop and you will need to set the flow rate
Apr 22, 2010 | Franklin Industries Franklin Chef Ice Cube...
MV450 SCOTTSMAN ICE MACHINE
Personally I think the prices that you paid for the new TXV and dryer are VERY far out of line.Get what information you can off of the TXV power assembly and valve body along with the manufacturer of the valve and I will see what I can find out for you. If it is the power assembly that is rusted out and leaking there are kits for replacement parts on most valves.
Oct 23, 2008 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
227 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
