Question about Pioneer DEH-245 CD Changer
Power unit does not power up when hooked up
  • 777l7 Jun 03, 2008
    thanks but i found the problem power strip inside was not clipped in securely keep that in mind its a good tip
  • 185 Answers
Ok then it might be bad or ur remote wire is hooked up wrong
Posted on Jun 03, 2008
522c went out on now, replaced with a LCX28c HD head unit! Lowrance said it would hook right up to existing power and sonar cables....it hooks up, but after powering the unit up, it shuts off after about...
Sounds like you may have an issue with low voltage to the unit. First verify your battery is in good condition. Connect the new power cable directly to the battery using appropriate fuse and test. If the problem goes away then the problem is with the wiring between the battery and the head unit.
Jun 19, 2013 | Boating
My power acoustic protection light stays on i got good ground and a good positive connection, no speakers or RCA's hooked up, what could it be
Are you fused close to the battery with a 30-50 amp fuse block?
Ground unit also to most closest suitable location!
Is your power wire undersized?
Check units fuses you may have blown one hooking it up!!
Good luck
Feb 15, 2011 | Power Acoustik LT-1920/2 Car Audio...
Hi i was hooking up my panasonic home theater with the power on i heard a sound and the power came try power it up went on display f61 and then shut off what seem to be the problem model...
Never hook up theater units with the power on, you need to have the fuse replaced in your unit. You need a trained tech. for this electrical problem.
Oct 19, 2010 | Panasonic SC-HT740 System
Stereo help
Make sure the red wire on the unit is hooked up to power. The blue antenna wire is hooked up (or to the factory amplifier) and the yellow wire on the radio is hooked up to a key on power supply. If it works and you lose the memory when you shut the key off, switch the red and yellow wire power supplies.
Feb 25, 2010 | 1987 Volvo 240
Ground wire was hooked up to a power wire...
My guess is it blew the power supply. Best bet would be to have a repair shop have a look.
May 04, 2009 | Audio Players & Recorders
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
Power unit on test for Kenwood kgc 7043
should not need the head unit.open up unit and start testing continuity along wire an board.possible break in connection.
Feb 24, 2009 | Kenwood Car Audio & Video
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
CAN I ADD A TV TUNER TO MY DUAL XDVD8181 HEAD UNIT
just hook up a vhs or dvd player from home that has tv outputs, but you would need a power inverter for the power supply of the vhs, then put the vhs audio and videos outputs to the dual's input: the auxiliars. make sure the vhs has channel changing.
Jan 08, 2008 | Dual XDVD8181 Car Video Player
Pioneer DEH-245 CD Changer Logo
103 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
