Question about LG DLE5977 Electric Dryer
LG Dryer DLE5977W will not dry in once cycle. Have to run it through at least 2 now. Dryer vent is clear. Disconnected vent hose and checked vent outlet in crawl-space - no obstruction at all.
  • 94 Answers
SOURCE: LG Dryer 5977 will not dry
If one of the two thermal fuses are blown you will not get heat.  Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot.  Often this is caused by not enough air flow through the machine.  Check and make sure your exhaust vent is not clogged.  Clean it the best you can to get all the lint, dead mice, bird nests, etc. out.  Also make sure air is blowing out of the machine when it is turned on.  If not you have a blower problem.
Posted on Oct 11, 2007
  • 34 Answers
SOURCE: Moisture sensor not working
This can easily be fixed by yourself. Just punch in the model number and look for the part number on fixya.com
Posted on Apr 17, 2009
mgprice
  • 744 Answers
SOURCE: Kenmore electric dryer heats but does not dry the
Hi, Here are the obvious parts to check: Heater, High limit, Thermal fuse or thermostats...these are all generally located in the back but some models you access them from front. the most common cause is either heater or thermal fuse, I will include a picture of the thermal fuse. If you test these parts and find they all work you may be looking at a centrifiacal switch problem.
Here is a picture of the thermal fuse check this part first:
http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
Please feel free to contact again if you have any other problems.
Hope this helps.
Posted on Jun 24, 2009
  • 17 Answers
SOURCE: Why would an electric dryer trip the breaker when
If the dryer trips the breaker when the vent hose is disconnected, you may have a faulty breaker or other problems in the dryer. It also means there is probably an obstruction in the vent line. More air flows out when the vent is disconnected, hence the dryer will pull more amps to move more air. An amp meter would be useful to see if it is less than the rated amps of the dryer or if it above it. If it pulls more than the rated amps with the hose disconnected, there is other problems in the dryer adding to the amp draw. Another check is to see if the breaker is equal to or greater than the rated ampacity of the dryer. Sometimes a simple clean & lube of the dryer will lower the amps by 5 or 10. A misplaced toy stuck in the wrong spot will add 5 or 10 amps to the load too. spin the fan & drive motors by hand while the dryer is unplugged to see if they are free. Lint & loose pocket items can build up around the fan to slow it down & pull more amps & move less air.
Posted on Dec 20, 2009
  • 45 Answers
SOURCE: lg dryer dle5977w heating element dryer
Yes the heating element is out.
Posted on Apr 28, 2010
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
LG dryer restarts after cycle
check one of the button are stuck first
Jul 22, 2013 | LG Dryers
Our LG DLE5977w dryer doesn't dry our clothes. The drum turns and there is heat, but it seems there is no air flow. We checked the vent hose and no clogs. When we cut it on the "drying"...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 18, 2011 | Dryers
LG DLE5977W Clothes Dryer takes forever to dry average loads of clothes. Authorized sevice tech recently cleaned air ducts and machine, but drying times per load takes hours. Any fixes to improve drying...
the most common problem is air flow restriction.make sure the machine is not pushed back to far and the ducting is getting kinked or blocked some how.when the machine is running go to the outside of your home and feel for the air blowing out of the dryer it should be pretty strong if it is not then there is a restrtion in the main line somewhere.and a leaf blower can be used on the inside of the house by sticking the tube in the vent hole and blowing it out but make sure that the outside part of the venting is clear so anything in the main line can come out.
Nov 17, 2010 | LG DLE5977 Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Our new lg dryer model #DLE1310w is not drying properly. We have 6 medium side towels that are not very wet in the dryer even on the hottest setting it is taking two cycles to dry the towels. When we...
Recheck the vent all the way to the outside and make sure the vent hose is not smashed behind the dryer.
Long time to dry complaints almost always are due to a restricted vent.
Remove vent to dryer and test a wet load if they dry ok then the house vent is at fault.
Jan 17, 2010 | LG Dryers
DLE5977W does not get our clothes dry. It seems to get hot, but...
check your dryer vent. more than likely the vent is clogged with lint or kinked.
Nov 25, 2009 | LG DLE5977 Electric Dryer
I put a small load of washing in the dryer and it doesn't dry and takes 2 or 3 drying cycles.
A restricted vent is the most common cause for long dry times. You can run a load of clothes with the vent hose disconnected from the back of the dryer. If you don't get any heat dring a cylce, and you verified an "air fluff" cycle has not been selected, I suggest having a professional service tech give you a diagnosis. The problem could be in one of a few thermostats, the heating element, main control (timer or control board), sensor, motor switch or even supply voltage.
Nov 04, 2009 | LG Dryers
Items in dryer are not quite dry, cool down cycle is real short, heat is maintained in dryer when it stops and wrinkles clothes. Cool down cycle went from 4 minutes down to one, skipping 3 and 2. Same...
check and make sure it has a clear clean vent.no kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
Mar 08, 2009 | LG DLE5955 Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
LG DLE5977 Electric Dryer Logo
187 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
