Question about Hitachi 60UX58K 61 in. Rear Projection Television
How can i manually adjust the convergence on 60ux58k hitatchi
    Brigadier General:
  • 8,909 Answers
In my experience, the convergeance is set up using the test mode and then is stored in an EEPROM. If the convergeance has gone out of tollerence a vast amount, it is unlikely that the EEPROM has lost its data and more likely there is a bad connection on a component or indeed a failed driver transistor or I/C.
The only thing you can do by moving the guns is the static convergeance. If that is the problem, slacken off the fixings and adjust the blue, leaving a cover on the red gun so you only see green and blue. Whwen that is satisfactory, cover the blue and uncover the red doing the same. That is all you can do without the test mode setting.
Hope that helps and mind your eyes, it is bright!
Posted on Oct 16, 2010
I have a 70' rear projection Hitatchi. the colors are no longer algined. how do i fix this
You will need to install the convergence repair kit for that chassis. www.tvrepairworld.com should have the repair kit you require.
Aug 27, 2010 | Hitachi Televison & Video
I have a Philips 46PP9302 and can't find the Quick Setup guide. I'm wondering if it is located on-line. We moved our tv and want to recalibrate it.
http://www.retrevo.com/support/Philips-46PP9302H-TVs-manual/id/278ci462/t/2/
The above link should take you to the location where you can view all the parts of your models manual. Select the area of interest and rad onlinje
Please rate my help++++Thanks for using FIXYA
Nov 24, 2009 | Philips 46PP9302 46" Rear Projection...
Hitatchi 53sbx10b
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Jul 19, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Convergence problem
The reason you can not adjust it is because there is hardware failure in the convergence board.
Visit this website and ask them for a convergence assembly for your TV. Once you replace that assembly, the convergence might still need to be adjusted manually.
Good Luck.
Apr 13, 2008 | Panasonic PT-56WX51 56" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
