Question about Whirlpool Dishwashers
Whirlpool model GU1200XTLS3 - water doesn't flow in properly unless i put in a pitcher or 2 of water. In the initial sensing/fill process and during rinse, i have to pour in pitchers of water, then water flows in as it should.
  • mtoliver Oct 23, 2010
    didn't fix it - i replaced the float and no change
    tried changing out the float, didn't work
  • Whirlpool Master
  • 17,130 Answers
Possible that the inlet valve , the level sensors are faulty, Most likely that the water level sensors are not reacting and cutting off the inlet valve unless the water level pressure comes in with the addition of the water into the chamber.
You must check the pressure switch of the level sensor, the connections to the program sensor , remove and flush the inlet valve from all dirt and reset.
Posted on Oct 23, 2010
  • Whirlpool Master
  • 3,247 Answers
The problem is in the water inlet system. See this diagram.
My opinion is the float system is playing up. This is stuck in dry condition and tells the controller it is full. So it stops taking water. But when you pour water manually, it frees up and start working normally which means the water inlet valve lets water in.
You may have to replace the float or press it a few times to ease the sticky spring.
Hope this helps. Please rate the solution if you found the solution helpful otherwiwe please post a comment.
Posted on Oct 16, 2010
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
Tip
Error codes
Samsung Washer Fault Codes
4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
5E WATER DRAIN ERROR 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON.
oE OVER-FLOW ERROR Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
UE UNBALANCE ERROR Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
HE WATER HEATER ERROR HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
1 E WATER PRESSURE SWITCH ERROR * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is aPRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
cE ABNORMAL WATER TEMPERATURE ERROR e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
11 E WATER LEAKAGE ERROR Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
tE THERMISTOR ERROR This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF.
3E MOTOR RESTRICTION ERROR Hall Sensor is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
8E OVER CURRENT ERROR IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
on Apr 14, 2015 | Washing Machines
Wont fill up with water
Do you get any water coming into the washer?
If water is not entering the washer, check that the incoming water valves are open and water flows through them. (Take off the hoses and put a bucket under the pipes.) Make sure that any filters are not clogged (for example with bits of damaged washer). Make sure that the hoses are not kinked. Next take off the hoses from the washer's fill valve and check if the filters are clogged (not present on all washers). Try replacing the hoses (there are anti-flood hoses that will seal themselves if they sense a leak). If that doesn't help, then the valves probably need to be replaced.
If water is entering the washer, check the filters at the inlet valves for partial blockages. Next check your water flow rate. (If the flow is too low, the washer may shut down. Check your manual for details or add a comment with the model number of your washer.) Next check if the water is being siphoned into the drain. This will occur if the drain hose is not positioned properly in the stand pipe (or sink). If the end of your drain hose is lower than the washer water level, this can happen.
I hope this helps.
Aug 11, 2011 | Whirlpool Washing Machines
During a normal wash cycle, the error code FH occurs. The owners manual says inlet problem. All water pressure is good and inlet screens are clear. Drain function appears to work well. Repair guy came...
If the flow meter does not register 10 and 1/2 gallons of water in 8 minutes the FH code appears.
Could be a bad flow meter, sensor, wiring harness is loose or a bad CCU Central Control Unit.
At the RINSE cycle if water enters the machine you must time the water fill for 8 minutes or less.
If water does not enter the machine suspect the CCU as bad.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Rinse cycle water flow slow
This problem is commonly attributed to a water inlet valve (also known as a "mixing valve") that is going bad. The water may appear to flow better during the intial fill cycle, because BOTH solenoids (HOT and COLD) are typically used during the initial FILL cycle. However, nearly all washers use a cold water RINSE. This means only one solenoid is energeized during the rinse cycle which reduces the water volume even more.
If you live in an area that has hard water, or if you use well water, the inlet valve and/or fill hose sediment screens can become clogged with sediment, calcified deposits and rust resulting in a restriction of water flow. You can try cleaning the sediment screens and the water inlet valve in a 50/50 solution of distilled vinegar and hot water to see if you can dissolve any sediment or deposits. Removing the valve from the washer and allowing it to soak in the solution for about 30 minutes, then flushing it with clean water can sometimes return an inlet valve to normal operation. If cleaning the valve does not work, however, you will need to replace it. The following link explains how:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list have helpful exploded view diagrams to assist you with locating and properly identifing any parts you may need. If the model number you listed this question under is correct, the Water Inlet Valve number is 285805 and is listed as item 18 under the "Controls and Rear Panel" parts listing. The average price is less than $20.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Jul 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
F20 keeps appearing on our Whirlpool Duet Steam Washing machine. We cannot finish a load of laundry.
ck to see if fill hoses are connected correctly and you have good water flow through BOTH hoses to washer connection..if control senses slow fill it will f20..do not try to use cold water onlyauto temp will try to use hot to adj prest temps and will fault if no water flow detected if ok ckd screens in washer end to be sure they are clean ..also ck to see if drain hose is proper height and not in stand pipe too tight ..water may be siphoning out and washer will not fill in allowed time
Sep 17, 2008 | Whirlpool Washing Machines
My dad gave me his Mr. Coffee Ice Tea Maker, but I have no instructions on how to use it. Can you please help?
Specifics may have changed for newer models -- we've had ours and used it happily for many years -- but the basics are simple.
(1) Fill the pitcher with water up to the "water" line and pour that water into the top of the appliance.
(2) Fill the pitcher with ice up to the "ice" line.
(3) Place a coffee filter and a family-sized tea bag into the top of the brew/steep basket and put the cover on that basket.
(4) Put the brew/steep basket on top of the pitcher.
(5) Slide the pitcher next to the appliance, such that the hot water exit port on the side of the appliance lines up with the entry port on the brew/steep basket.
(6) Press the "on" switch on the front of the appliance and wait for the tea to brew.
(7) When the brewing/steeping process is over, the appliance turns itself off.  Replace the brew/steep basket with the pitcher lid for pouring and storage.  Discard the tea bag and coffee filter, and rinse the brew/steep basket.
(8) Enjoy your tea!
Aug 17, 2008 | Hamilton Beach Iced Tea Maker
Message on screen 8E, Motor won't start on spin cycle. Model no Q1435(C/S/V)
This is what I found:
11. OVER CURRENT ERROR - Display shows 8E .
- IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
IPM : Integrated power module. , IPM controls motor.
- If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
the motor stops immediately. However, during dehydrating stage the signal is to be sensed
when the number of signal is more than 6 for 500ms.
- During Cleansing or Rinsing
When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
If the stopping of the motor working is happens in one direction ten times,
- During dehydrating
When the overload is sensed, the motor stops to work at once and then feeds back to the initial
When the feed back is continuously happened 2 times, "8E" Error is displayed
During the dehydrating unbalance sensing, No error happens by overload sensing.
-Power S/W Off can clear the overload error.
in short: imbalance problem
In a german forum one guy solved the problem by replacing the motor electronics. I am currently experiencing the same problem. I keep you posted.
May 08, 2008 | Washing Machines
Dishwashers Logo
81 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
