Question about Samsung RF217ABRS (197 cu ft) Bottom Freezer French Door Refrigerator
You helped me with quick response to my french door fridge icing up. You gave me advise to clean drain in bottom of freezer. Is this still the case, because my icing is in the refridge part, not the freezer.....this sight also does not recognize my type of samsung.. I have a # E3CE56CF french door. The leaking comes out the door, drips down to the floor. Also if there is a drain in bottom of freezer, is it visible to clean out? Thanks for the help, Michael
mikedurland
  • 481 Answers
SOURCE: our Samsung fridge freezer is
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 27, 2008
SOURCE: I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
Posted on Nov 07, 2008
SOURCE: samsung frost free fridge freezer ices bottom of freezer
it means that the freezer heater is bad, it's located after you remove the racks from the freezer and removing the back panel, it's at the bottom or below the condenser.
Posted on Dec 12, 2008
  • 9 Answers
SOURCE: I'm getting frost in freezer of my Samsung french
i would check the magnetic seal around the door to make sure it is not letting air in ...this is the cause of the over freezing.
Posted on Jul 13, 2009
SOURCE: no ice coming out of my ice maker
did you turn the water on if so when you tightened the water line you might have tightened it to tight and crushed the water line
Posted on Apr 16, 2010
My Samsung French Door, Bottom Freezer Model RFG297AARS was leaking into the refrigerator & pooling under the deli drawer.
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 05, 2015 | Samsung RFG297AARS Bottom Freezer French...
I have a Samsung french door fridge.
Apr 02, 2015 | Samsung RFG297AAWP Side by Side Bottom...
Why is there ice in the bottom of the crisper?
Sep 07, 2014 | Samsung RF217ABPN Bottom Freezer French...
Why Icing on bottom freezer
Your drain hose in the bottom back of the freezer is clogged and Iced up and all the defrost water is staying in the freezer and building up. You need to take the freezer back panel off, remove all the ice, defrost the drain, clean, flush with hot water and test the drain line to reach the drain pan under the fridge.
Aug 18, 2014 | Whirlpool Whirpool 26 cu. ft. French Door...
Why do ice build up under the crisper drawers in my Samsung French door fridge, and how to fix it
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.;
Jun 07, 2014 | Samsung RF265AA Bottom Freezer French Door...
My freezer is making ice at the bottem
I had this problem. The cause is water generated during defrost cycle that cannot drain into pan in back of fridge due to a plugged drain pipe. Ice builds up into a dam, and the water has no where to go except to bottom of freezer housing. Eventually this builds up with ice and runs out the bottom seal. Solution requires 2 things. First is empty fridge and freezer and disassemble freezer to expose frozen over evap coil. Melt this ice with hair dryer, lots of towels and patience. Then clean up drain pipe which is accessible from rear of unit after removing metal cover. The plastic pipe has a small black cap with a hole in it that is designed to let water flow out but keep spiders and such from getting in. On my unit this cap had sticky greasy deposits in it, was a bit stiff. I cleaned it thouroughly with mineral spirits, reinstalled and all is now a okay. Hope that helps.
Sep 05, 2013 | KitchenAid KFCS22EVMS Stainless Steel ...
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
My freezer has bad ice build up on bottom and were air comes out
You have a drain pluged up in the freezer. You need to remove the bottom door and rollers take the back panel off and clear the drain.Use hot water after you get most of the ice out and take the back off the fridge and look for water to come in the pan.
Sep 19, 2011 | Whirlpool GX5FHTXT Bottom Freezer French...
I appreciate the quick and thorough response! I apologize but I am a very novice and this is my first attempt at any repair. I am not sure what/where I need to be looking to find the drain tube to remove...
you will need to remove the rear back panel inside the freezer to access the evaporator core area,there is a drip tray located below the evaporator core,this item can be removed by loosening the mounting screws,cleaned and replaced
Jan 08, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Samsung RF217ABRS (197 cu ft) Bottom Freezer French Door Refrigerator Logo
65 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
