Question about Tomtom ONE 3rd Edition GPS
Delete destinations saved in favourites - Tomtom ONE 3rd Edition GPS
    President:
  • 4,070 Answers
Hi! You may perform the deletion by linking the unit to the pc.
Posted on Oct 16, 2010
4 Suggested Answers
SOURCE: Memory Full
thank you this has solved my problem
britenick
Posted on Dec 10, 2007
smilemaker
  • 790 Answers
SOURCE: memory full, cant delete stored
Hello vinny!!
Perform a hard reset to clear all your memory!!!
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. Choose "Clear Waypoints". After some time the unit should reboot.
Posted on Jul 12, 2008
  • 587 Answers
SOURCE: garmin 1490t
Not sure how your unit works but I would look at what you have it set at traveling by Auto.... Bicycle or Off Road
Tools ... Settings... System... look at Usage Mode make sure it is set to Automobile if traveling by car
Posted on Nov 07, 2010
I cannot scan my documents. I got a message from Scansnap: La destination specifiee (dossier d'enregistrement des images) est incorrecte. Specifiez une nouvelle fois la destination.
Go to the settings of Scansnap and look for save folder or destination folder. The error message usually appears when the destination folder has been deleted.
Mar 28, 2017 | The Computers & Internet
Address delete
I don't think there is an option to delete an address or your recent destinations. If you really want to delete an address, because nobody needs t know, the only option is to set back to factory options. But that will also deleet al your settings and favourites.
If you want to edit (and or delete favourites) there is a menu optie in Change preferences called Manage Favourites
If you want to hide your destinations, you could protect your device with a 4-digit password, but for that you must connect the device to a computer and use TomTom Home.
In the menu preferences choose Set Owner.
Oct 13, 2013 | Tomtom ONE XL GPS
How do I delete items from recently found? How do
When you want to add a place to your favourites
  • Press WHERE TO
  • Enter the address
  • Instead of pressing GO press SAVE at the bottom of the screen or press VIEW MAP and then SAVE
It will be saved to your favourites folder and the keyboard will come up for you to give it a name.
You don't delete items from recently found. A certain number of items are kept there and overwritten as new ones replace older ones.
Jun 17, 2011 | Garmin nuvi 255W GPS Receiver
Hi I recently purchased a garmin nuvi 1410 and tried programming several sites in. however when i left one site and wanted to navigate onto the next, it kept trying to bring me back to the previous site...
Hi, there are 2 possible solutions to your problem.
1. Press WHERE TO and enter your first address. Instead of pressing GO press SAVE, at the bottom of the screen. This will save the site in your FAVOURITES folder. Repeat for each destination. Then when you want to go to one of these addresses just press WHERE TO then press FAVOURITES and select the address from it. If you're going to use these addresses fairly often then this is probably the best solution. When you reach your destination sometimes the satnav doesn't realise you have as, for example, you could be on the wrong side of the street to where it expects you to be or the satnav could be out by a few yards. When this happens it tries to get you to go back. To stop this press MENU at the bottom of the screen and then press STOP. (The STOP icon only appears while the satnav is trying to take you to a location) Having done this you can then select your next destination.
2. The second option for solving your problem is to enter your last destination first and press GO. Then enter your second last and when you press GO again it will ask you if you want to set this as a VIA point. Select YES. Add each destination in turn making them all VIA points. When you do this the satnav will take you to the last via point first and then each of the others on the way to your destination. The advantage of this method is that you don't have to set destinations when you're traveling. As soon as you reach one it adjusts to take you to the next. The disadvantages are that if you want to go to the same destinations again you need to re-enter all the information again. Also if the satnav thinks you have not reached your via point, when you have, pressing STOP cancels the whole route.
Entering the places into FAVOURITES is probably the best option. Note once they're in FAVOURITES you can rename them if you wish or you can delete them. You'll find details of how to do so on page 12 and 13 of the manual available in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
May 09, 2011 | Garmin Nuvi 1410 Car GPS Receiver
How do i save add to fav place
Favourites are places / addresses that you want to keep on file.
To add an address to your list of Favourites ...
From the Main Menu, tap Add Favourite.
You can then select the location of the Favourite from: an address (that you enter), your Home, or a recent destination, a point of interest, your current position/location, or a position that you tap on the map browser.
Feb 13, 2011 | Tomtom XXL 550 Car GPS Receiver
How do I delete addresses from my Tomtom?
There are two ways
One is from the TOMTOM itself
Touch the map display once.
Select the spanner / wrench icon
Press the right arrow until you see MANAGE FAVOURITES.
Select the one you wish to delete and the display will change.
At the bottom of the screen will be a DELETE button use that.
It will ask for confirmation click YES.
Click DONE when you have finished.
Two is via TOMTOM home
Start TTH
Connect your GPS
Start the GPS
TTH will probably offer you updates (let it do its thing)
When the update is done use the right arrow on your PC display and select OPERATE My TOMTOM
Now use the same method as you did above.
To delete ALL recent destinations
Touch the map once
Touch NAVIGATE TO
Select RECENT DESTINATIONS
Now select DELETE
It will ask for confirmation select YES
they will all be deleted and the flag will grey out .
Touch BACK
Touch DONE.
Sep 07, 2009 | Tomtom ONE GPS Receiver
TOMTOM one XL has deleted favourite locations
I think that just means there are no favourite destinations.
Just add a destination and save it as favourite. The button should be enabled again.
Aug 14, 2009 | Tomtom One XL GPS Receiver
Dear Sir/Madam, Can you advice me Please? How to clear previous destination and favourites from Tomtom which are no longer required. Thank you. Ajit Agrwal ajitagrwal@hotmail.com
clearing route
tap the screen tap the right pointing arrow tap clear route tap yes
clearing favorite
tap the screen tap change preferences tap the right pointing arrow tap manage favorites select the one you want to delete tap delete tap yes
Apr 25, 2009 | Tomtom ONE GPS Receiver
How do i permenantly delete destinations
hi if you have a card reader use this to read your sd card delete the file called opts.dat this is in navigator folder on sd card this will delete your favourite places the sat nav automatically makes a new one when new places are saved, good luck
Jun 03, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
37 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
