Question about Hotpoint WMA54 Front Load Washer
My machine stopped spinning, instead the red cycle lights lit up in turn, backwards and forwards. I've cleaned out the filter trap which did have a collection of coins, curtain hooks and a button along with gunge, I have also disconnected the hose from the drain pump and checked for blockages, nothing there. I put it on a rinse and spin cycle and it seemed to do everything working fine. Then when putting the machine back into place I accidentally pressed the start button putting it into another rinse/spin cycle, this time the machine did not spin and the error display of lights turning on and off in a 'wave' appeared again?
  • nickparker19 Oct 17, 2010
    "What this code indicate that there has been a loose wire some well from
    then wiring connection or an in balance on the drum e.t.c."
    What does this mean? Are you saying that the error display I'm seeing indicates that it could be a loose connection somewhere or a faulty switch? I'm thinking that it could be a pressure switch related to load weight? what do you think?
    Genius:
  • 1,416 Answers
What this code indicate that there has been a loose wire some well from then wiring connection or an in balance on the drum e.t.c.
However, here are the likely solution to solve the washer from this problem below
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Here bare likely problem of the washer and their solutions below,
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • hope this help ?
    Thank you and thanks for using fixay.
    Posted on Oct 16, 2010
    Kenmore HE2 flashing lights
    did the technician point out wat needs to be repaired
    Aug 24, 2008 | Kenmore 46462 Front Load Washer
    Whirlpool Front Loader WFS1071BW, rinse cycle problem
    I had exactly the same problem with the same machine... I've seen a few people on various forums with the same problem. The problem on mine turned out to be just the EMI filter located next to the power cord inlet. I just bypassed it for now until I can get a replacement.
    Apr 26, 2013 | Washing Machines
    ASKO W6903 spin cycle not getting to speed
    Again it could be the carbon brushes or a faulty motor tacho
    hope this helps
    Mar 09, 2013 | Washing Machines
    I have a whirlpool awo 3751/5 During the spin cycle it showed up with F09 error, I've switched to drain cycle now and it keeps displaying FP I have opened the filter cartridge at bottom and there...
    Remove power for a while and allow the machine to reset. Now it is important that the drain pump be removed and checked to see if there is any dirt trapped and causing the pump to overload. Also check the inlet flow , if low it must be removed and backflushed to improve the flow. The door swithch must be checked as also the water level switch. Make sure that after removing the panel that the connections to the program module is intact. Finally check the motor drive , check for free movement of the agitator, if not check this assembly , the belt, bearings and the shaft.
    Sep 27, 2011 | Washing Machines
    My washing machine stopped at the spin cycle and just went, "beep beep beep" I reset it, both with, and without, the clothes inside, but it won't spin.
    Hi just read your posting.Now when the machine beeped, a series of lights would have lit up.They will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
    Sep 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
    Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
    Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
    Jul 27, 2010 | Fisher and Paykel Washing Machines
    Water leakage after cleaning lint trap
    make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
    Apr 07, 2010 | Miele W1926A Front Load Washer
    Clean pump light is on - how do i do it?
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It’s not possible to give specific information on how to remove or clean your pump or filter because you never stated which make or model you have! But if you follow the outlet hose back into the machine it will lead you to the pump and the other hose coming off the pump will go to the sump/filter. It is then just a case of removing the hoses and cleaning out any blockage from inside. Be sure to turn off the power and empty the tub of as much water as possible first or you will end up with a soaked floor, it will also be an advantage if you can tilt the machine away from the pump before removing any hoses. (If the pump is at the rear of the machine tilt it forward and place a shallow bowl or dish under it to catch any water. Keep the machine tilted by putting a tin of soup or something under it. If it is at the front then tilt it backwards.)
    Mar 04, 2010 | Whirlpool Washing Machines
    Won't spin or drain, have tried to rerun cycle and checked drain hose
    Check pump / outlet filter , refer to instruction book , clean and replace then re- try
    Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Hotpoint WMA54 Front Load Washer Logo
    Top Hotpoint Washing Machines Experts
    Todd Arndt
    Todd Arndt
    freddyfox
    ptpumpman
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
