Question about Smeg FR158SE 1 Compact Refrigerator
SMEG FR158 completely stopped cooling Light is still burning, so power supply is no issue Trying to figure out if its the thermostat oor the motor that's broken
Why is my smeg fridge not keeping anything cool
Hi...the same thing has happened to me. My Smeg Fab28 refrigerator compartment has stopped cooling. The freezer still works. There was a build up of ice on the back fridge wall, and the milk was freezing up, so I turned down the temp. After the ice melted, I heard a bang like a bunch of ice had dropped. I turned the temp back up but it steadily stopped cooling even more. I decided to defrost the freezer, and had the power off completely for about 5 hours. When I turned it back on, the freezer worked, but the fridge is not cooling AT ALL.
Did you fix the problem and if so, how?
Thank you
Bev
Jun 02, 2014 | Smeg Refrigerators
Fr158 smeg stopped working ? light on motor not running
Need more detail. Exactly what is a smeg, which motor are you talking about.... Want a technicial problem fix? I need some technicial specifics in detail.
Oct 12, 2013 | Smeg FR158SE 1 Compact Refrigerator
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 13, 2013 | Smeg Ovens
Smeg gb-ie
Jul 12, 2013 | Smeg Ovens
SMEG OVEN BRAND NEW WON'T HEAT
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Sep 08, 2012 | Smeg Ovens
Smeg oven stopped working
Jan 27, 2012 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
Nov 30, 2011 | Smeg Ovens
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
Nov 29, 2011 | Smeg Ovens
Smeg electric oven model sa22xmf/7 not heating at all after power turned off
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
Jul 07, 2011 | Smeg Ovens
Smeg FR158SE 1 Compact Refrigerator Logo
43 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
