I have a Whirlpool D25 Water Cooler that no longer dispenses cold water. Thought this might be a filter issue, but there is no filter according to the manual?
aborcass
  • 2651 Answers
SOURCE: Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Posted on Mar 02, 2008
jsrock516
  • 5911 Answers
SOURCE: Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Posted on Sep 03, 2008
  • 958 Answers
SOURCE: Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
scottludwig3
  • 4 Answers
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
Posted on Nov 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Posted on Sep 30, 2010
Changed filter recently now the water dispenser is really slow
Check the filter membrane specification with the old and new both are same. If the valve high water flow will gradually decrees.
Aug 22, 2016 | Whirlpool Gold 25.6 cu. ft. French Door...
I have a 2 year old whirlpool water cooler that no longer dispenses hot water. Any possible easy fixes for this?
I hope this doesn't sound insulting, but there is a switch in the back that controls uniquely the hot water, is it set to on?
Dec 25, 2010 | Whirlpool Refrigerators
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
SUNBEAM WATER HEATER/COOLER WITH WATER FILTRATION BOOTLE
i am having the same problem and i lost the model number for it but can you please share the modle number if you have it because i call sunbeam and they need it so they can find it for me! thaky e mail @ hateandlove_1988@yahoo.com
May 23, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Whirlpool ED22PW water not reaching ice maker or front dispenser
It doesn't matter if a whirlpool or any other brand is new or not, if you don't use an inlet water filter the water will taste like **** and sediment will deposit and cause catastrophic ice maker and water dispenser failure.
Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Dispenser full of water
believe it or not whirlpool says that's normal its in your owners manuel under dispenser because the washer mixes the bleach soap fabric softener with water for it to dispense they say its normal for water to remain but if you want to empty it there is a tab that you can press down on in the dispenser and remove it have a bowl handy
Jan 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
839 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
