Question about GE Spacemaker Washer and Dryer Electric Laundry Center
The filter in my washing machine is came off loose and broken in the process. I need to get a replacement. secondly my dryer filter is broken as well. where can I get the replacements? pl reply to minpa60@gmail.com. thanks for your time.
  • GE Master
  • 3,361 Answers
Go to www.repairclinic.com put your model number in the search box and order your part.
Posted on Oct 16, 2010
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
Aug 02, 2011 | Washing Machines
The wash machine spills the water before the process .
If water is spilled before the wash process, then you have a broken seal in the water inlet which needs to be replaced!!!
Jan 20, 2011 | GE WBSR3140DW Top Load Washer
Machine won't spin.
Could be a lot of causes (worn/broken belt, bad switch, broken pulley, bad motor... etc). If your not sure of what it needs/ unsure of the repair process you'll either need to call a repair man or replace unit.
Oct 23, 2010 | Whirlpool LTE5243D Top Load Stacked...
My Frigidaire GLEH1642DS washer drum is loose and bangs when washing
on the top of machine is a cement block,yes a cement block.it balances the drum, well in your case i think its broken and needs replaced.adrian,,,,,,,
Jul 06, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Banging washing machine on spins
Hi. I don't know if your problem has been sorted yet, if it has not ,then it sounds to me llke the concrete balance weight is loose or broken
There are 2 of them, one in the top of the m/c, and one at the bottom, if either of them are loose, then that is your problem.
If loose, can be tightened up, if broken away from the drum then you have a major problem
Nov 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Won't fill
was the machine laid down for repair,check to see if there is a loose wire
Mar 01, 2008 | Fisher Paykel EcoSmart GWL15
Replace belt
Before offering assistance I need to know if the old belt is still on the machine and in tact. The procedure is a little different if the belt has broken.
Dec 08, 2007 | Frigidaire FEX831CS Top Load Stacked...
Tricty bindix
Sounds like you have a broken drive belt - if a washing machine doesn't spin, the usual cause is that the belt that goes between the motor and the wash tub has worn out and broken.
The usual procedure is to open the top of the unit and locate and remove the broken belt and replace with a brand new belt, the most expensive part of this repair is the labor, and it is not that difficult for most models if you have some basic tools.
Will need your specific make and model of unit in order to look up the part number of the belt and find out how easy the replacement process is, if you can leave this information, perhaps I can help more. :)
Nov 16, 2007 | Washing Machines
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
51 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
