Question about LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator
Lg lsc27910tt water/ice dispenser sticks in the on position and water/ice will not stop dispensing. how do i fix this problem?
I had the same issue with mine but it is fairly easy to fix, all you need is patience.
1. Press the "Lock" button to ensure nothing is dispensed while performing the fix (worth testing).
2. Remove the grey rubber push from the dispenser carefully (give this part a wash in warm soapy water and leave to dry).
I used a small flat bladed screwdriver but BE CAREFUL not to damage it on removal.
3. Spray a small amount of WD40 (or similar oil) using the straw attachment into the mechanism, especially the spring.
4. Work the mechanism a few times (observe point #1) to ensure it is not sticking.
5. Get a chair.
6. Re-fit the rubber surround following these tips:
a) Starting at the top on the right hand side start gently pushing the rubber lip into the chrome surround.
b) Ensure as you work around the rubber that the legs locate into the holes (use the small screwdriver to guide them in).
c) Work around clockwise using the screwdriver to ease the rubber into the chrome surround.
d) Once in place you can work around again with the handle of the screwdriver putting slightly more pressure on the edge of the rubber (where it meets the metal surround, this will ensure that it locks back under the lip.
***Be patient when refitting the rubber part, it takes a good 15-20 minutes but not doing it right will result in more problems***
Hope this helps!
Posted on Feb 11, 2011
My ice make stop dispensing my ice out. First cube was crush and crush was crush. then it just stop disepensing my ice. I can hear it in motion , but nothing. I clock turn it 1/4 but nothing. Please help. thanks
Posted on Aug 14, 2011
How do I fix the water dispenser on my LG refrigerator?
#1 cause is the water filter. There may be other blockages in the line. Change the filter one more time and allow the air to purge out of the line. You will make a mess.
Nov 12, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
How to investigate the problem with the ice dispenser on my LG LSC27910TT?
what is it doing? is it making ice? is water getting to the tray? are ice cubes small? large?
Jun 05, 2014 | LG LSC27910TT (265 cu ft) Side by Side...
My LG ref. stop dispensing water and ice. make ice but it doesnt dispense it.
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
Dec 18, 2012 | LG LSC26905TT Side by Side Refrigerator
Electrolux EI23CS55GSI - Water Dispenser Will Not Stop Running
sounds like the paddle you push to dispense the ice and water is sticking,if there's a rubber pad there try moving it to see if it frees it up,if not it looks like you have to replace the whole part 242100018 go here to see it
https://www.repairclinic.com/PartDetail/Dispenser/242100018/3513417
Jan 18, 2018 | Electrolux Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
Water/ice dispenser sticking on
We had a problem with the water/ice dispenser on our 5-year-old LG SxS Refrigerator (LRSC 26930TT). In a panic to stop the water flow, the rubber activator boot was pulled off. The dispenser stopped once the button attached to the back of the boot was removed. Nothing was physically broken (i.e., parts intact) but the challenge was to get things (especially the boot) back in place. The key for me was to use patience: researched Internet for pointers (not too helpful), looked for schematics (even less fruitful) and exhaustively examined the panel on refrigerator (to help reverse engineer). Okay, here’s how I disassembled and reassembled without breaking any tabs or other pieces. Assuming your unit is similar, the panel is on the freezer door on the left side. You can lock the dispenser (using panel button) to preclude undesired water/ice while working. Note: the outer bezel (edge of panel) is secured by screws and should not be messed with. The main panel has tabs on all four sides. I used three screwdrivers (small to average in size) to pry the panel off. Pry the main panel working through the seam between the bezel and panel. Work your way around starting from the lower left or upper left corner. Each side of the panel has 3 or 4 tabs. Methodically work your way around using moderate force to pop the tabs loose. Once the panel is loose, you’ll need to disconnect the electrical connector at the upper left. The plug comes off and reattaches easily…don’t pull on the wires, use the plastic connector itself. Wiggle the panel free. Now you can get to the back of the boot retention bezel…the ultimate goal. Carefully push the bezel’s securing tabs (x3) through the panel and reattach the rubber boot. I used needle nose pliers to carefully pull each rubber nib through their applicable hole on the bezel. Now leave the boot/bezel assembly to the side—it’s the last step to reassembly. Note how the main panel tabs fit into their receiving slots/flanges. Reattach the electrical connector, snaps right on, and maneuver center of panel into recessed area, around ice chute/water nozzle. Slide the right and bottom sides on first—flanges, not slots for tabs—then align remainder of panel. Using moderate force, pop (punch) the remaining tabs back into their respective slots. The main panel will seat over the bezel. Now align and snap boot/bezel back into place. Finis! (No guarantees, but this procedure worked like a charm for me.)
Sep 11, 2009 | LG LRSC-26922 Side by Side Refrigerator
Stuck Water/Ice Dispenser LG LRSC26920TT
THE ACTUAL BUTTON AND ACTUATOR NEEDS CHANGING AND POSSIBLY THE SWITCH. EARLIER MODELS WERE CHANGED BECAUSE OF THIS.
Aug 18, 2009 | LG LRSC-26922 Side by Side Refrigerator
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
LG LSC27910TT (265 cu ft) Side by Side Commercial Refrigerator Logo
816 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
