Question about Electric Health & Beauty
Joystick lights all flash,new batteries,doesn't move.
    Novelist:
    Champion:
  • 232 Answers
The number of lights that are flashing can indicate what the problem is. Make sure that all of the battery connections are tight and the fuses are good. Try to reset any circuits like the freewheel/brake lever. You can also visit this site for help:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the type of controller on your power chair to see what the flashing lights are trying to tell you.
Posted on Oct 20, 2010
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
dromtonpa
  • 40 Answers
SOURCE: problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Posted on Apr 01, 2009
  • 5 Answers
SOURCE: lights flashing
Are you sure that your batteries are not just able to hold a charge? Flashing lights and slow motion are typical indicators.
Posted on Oct 16, 2009
SOURCE: the charge indicator lights flash left to
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Posted on Jun 16, 2010
  • 63 Answers
SOURCE: Dynamic Joystick Controller, all lights flashing 5
follow that joystick cable make sure it hasn't been pinched also i would make sure everything is connected ,you could have dis connected something on accident.
Posted on Jan 17, 2011
Joystick lights flash red to green and repeat over and over. Just replaced batteries with new ones and can't operate joystick. Also the joystick yellow service light flashes at the same time. Do I need...
I hope you still have the batteries,as there is a service that can bring batteries back to life.Try contacting your nearest repair service for your product.There are charity run businesses that hire disability aids for getting around town for the day.Give them your question and ask about the battery service I refer to.I hope this helped you,Colin
Feb 27, 2015 | Invacare Pronto M51 Power Wheelchair
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
My mom has a Aspire M11 Quickie Power Chair. Today, out of the blue she was sitting in front of the TV and the power indicator lights start flashing and the chair would not move. We have tried charging...
Check to see that both motors are in the "engage" position. If they are, the problem could be in the joystick, or the communications cable between the joystick and the controller. If you can't find the problem, call your dealer and tell them how many lights are flashing. This will give them a better idea of what's going on. Good Luck!
Sep 05, 2011 | Health & Beauty
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
Lights flashing
Aug 27, 2009 | Invacare Pronto M51 Power Wheelchair
Problem with joystick on Jazzy 1103 ultra
Apr 01, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Health & Beauty Logo
129 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
