Problem with philips Powerhouse AW626 music System
My left channel consisiting of speaker and tweeter doesn't work but my right channel works properly and sometimes it works properly and the next day the distortion starts coming in the left channel
  • 682 Answers
Try to invert your speakers cables and connect your right speaker cable to left output if the problem still happened you will have a problem in your amp and ask for help from good service center near you-------if the problem disappear you will have a problem in left channel----cable or speaker.
Posted on Aug 02, 2008
I have polk audio rm 705 purchased from my friend a month ago. these are working fine but one day one speaker just have very low sound coming from tweeter where as the main speaker is silent.
Try switching the speakers left to right. If the same speaker is bad on both channels, the speaker is bad. If the good speaker is now bad, the unit driving the speakers is bad.
May 23, 2015 | Polk Audio Rm705 5.1 Channel Home Theater...
Why did my receiver lose volume on the right channel
I will assume this right channel problem is present no-matter the chosen input....radio, CD, etc. "Changed speaker wires"...did you swap ONLY the wires from left channel to right or did you also swap speakers? Defective speaker woofers (wiring and/or crossover failures) leave only the tweeter to reproduce music in that speaker, which we perceive as both a huge volume and tonal reproduction difference compared to the "other" speaker. Keep up your "process of elimination" troubleshooting techniques as this will lead you to the problem.
Mar 27, 2015 | Audio Players & Recorders
My Technics SU A700 mk2, doesn't have any signal in right channel. During (i am first owner)time I noticed that I had that right channel performance reduced arround 15% compared with the left one. ...
Have you tried cross-plugging the speaker cables (i.e. swapping left and right channels) to be absolutely sure it is the amp ? I have a speaker that needs a fair amount of volume to wake it up, but after that performs well.
Jun 15, 2017 | Cameras
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
I have a problem with my car speaker/tweeter
Sounds like you have the ground and live possibly the other way around from the head unit to the speakers. The reason for you hearing it from both the tweeter and the speaker is that the tweeter is connected in parallel to the speaker.
Swap the wiring and try it.
Mar 21, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Speakers
The connection between the TV and the Philips for the left channel is missing or interupted.
There should be two connectors on each end, one red (right) one white (left).
If they are properly plugged in, then the left channel cable stretch is bad. These can be replaced inexpensively at any electronics store.
The sound when using the player is sent internally to the amplifier of the system; no cables.
Aug 17, 2008 | Philips HTS-6500/37 System
I have a kenwwod AX-7 home theatre systems. the right side top speaker (tweeter) on one side does not work. i'm thinking there is a fualt with the amplifier on the right side.
If the only problem is the tweeter, and the woofer is still working, you do not have a problem in the amplifier. The problem is the speaker. The tweeter is blown or you have a problem in the cross over network in the speaker.
You can always switch the speakers and connect them to the opposite channel. You can do this very easy at the back of the receiver where the speaker wires are at. Put the left speaker wires on the right speaker and the right speaker wires on the left speaker. If the same speaker still has no tweeter you know that the speaker is the problem.
The only way this could be a problem in the amplifier is if you have two different sets of inputs for each speaker, one being the low end for the woofer and the other being the high end for the mid range and tweeter. That would mean you have two sets of speaker wires going to each speaker. Each set of speaker wires would have a positive wire and a negative wire for a total of 4 wires going to each speaker. I don't remember this system being set up that way, but I could be wrong.
I hope this was helpful, you should be able to get the speaker fixed at an authorized Kenwood repair center in your area for a reasonable price. As a guide, my shop only charges $25 for the labor plus the cost of the tweeter to replace a tweeter. Any other shop should be similar. Kenwood does sell replacement drivers for almost all of their speakers.
Jun 21, 2008 | Kenwood Audio Players & Recorders
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
259 people viewed this question
 Grubhead
Grubhead
