Hi! My Kelvinator extreme aqua kl60dfl keeps on flashing err 1. It doesn't help to switch it off and the other buttons doens't respond. What is err 1? Please help!
3 Suggested Answers
jan mczeal
  • 632 Answers
SOURCE: my washing machine kelvinator aqua
Unplug the machine then drain the water manually by gravity. Place the drain hose into a bucket or shallow basin on the floor to drain the water. Water should gush down the drain hose if the drain system including the drain hose is clear. This signifies that the drain pump is not working. Check to make sure that the drain hose is not clogged or kinked and the drain pump filter, if there's any, is clear if water does not flow down the drain hose. Also check the drain pump for any sign of degradation or damage.
Posted on Sep 13, 2010
  • 6277 Answers
SOURCE: PCB (computer) faulty Kelvinator KL60DFL
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 25, 2011
I have Kelvinator AQUA EXTREME KL600FL lost manual and now dont know how to do the various settings for washing programmes
I am including a link to the kelvinator support center. It seems that KL600FL may not be the complete model number because the site does not answer anything for that number. . Open the lid or door and look around the frame for a model number label.
Support centre
Oct 03, 2014 | Washing Machines
Control panel and no pumps
do you have the control box cover off? some have a safety switch that will shut the tub down if the cover is removed..find this button and tape it down.. check the rest of the switches for proper operation..either from remote or on the unit..its a process of elimination thing.. I have been doing this for 4 days on our tub.. its finally heating now..only thing is the air blower is not working..
Jan 05, 2014 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
I have canon ip2000 printer, the screen shows error 5B00(The waste ink tank is full). the LED flashes, 1 Green(stable about 2 sec.), then orange/green, orange/green ..... 7 times(fast about 1/2 sec....
In case you haven't tried this before, here is a tip that should reset the printer.
Copied from site: http://www.cyber-ink.com/member-canon.html
To Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Also note that if the carriage is not moving as it should, it has nothing to do with printer drivers or your computer. It is an internal function of the printer and no external connection (usb/ethernet) should affect its operations.
Oct 16, 2013 | Canon PIXMA iP2000
Kelvinator aqua error 1
Possible that the main program controller unit has failed or is having faults within the system.
Dec 31, 2012 | Washing Machines
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
Spares Suppliers
John C.
Apr 25, 2011 | Washing Machines
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
Jan 20, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
