Question about Microsoft Xbox 360 Console
Im have problems setting up xbox live with my pc useing wireless. HELP
    Problem Solver:
  • 5 Answers
This link might help you out. Found it on the Microsoft support section. Different from when I had to set up wireless. Wireless How-To
Posted on Oct 16, 2010
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
I want to Connect to Xbox Live (Xbox 360 Slim). I have an Xbox Live Account and an Xbox 360 Slim (250 gig). I have an Apple Imac G5 using OS X. Im also using a Verizon Wireless Access portable USB to...
This is arare problem ............ i faced similar kind of problem
i solved my problem with the help this repairguide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Aug 15, 2010 | Microsoft Xbox 360 Console
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
Cant connect to live...wireless.
Basically i know its a rip off but if u wanna use wireless with the xbox 360 u need to buy the official xbox 360 wireless router which is about £60.There is another way if u dont use wireless u can connect the xbox 360 to a router or the phone line then go to your windows firewall and set it up manually.Hope this can help you .Joe stevenson
Jan 22, 2009 | Microsoft Xbox 360 Console
Xbox live wireless network failure
did you go into your computer settings? i think you have to take your firewall off maybe. im not totally sure on this one. good luck though! if you call microsoft they might have better answers sorry!
Dec 27, 2008 | Microsoft Xbox 360 Console
Wireless network always fails for xbox live.. i need help
go to settings and conection settings and put your connection setings in
Dec 26, 2008 | Microsoft Xbox 360 Console
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
Tips:
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
Boost signal to allow xbox live
1 buy and cantenna and a hawking hwug1 (from hawking website). install hawking on computer (usb wireless device) and then run the network wizard to make the connection a proxy server. run a lan cable from the computer to the xbox, and enable the wireless connection on the laptop to be shared with other computers on the network.
Sep 25, 2008 | HP Pavilion dv6000z Notebook
Xobx live!
When you go to your network setting page, you arent supposed to manually type in the data. You are supposed to keep it on automatic. **Notice how on that page there are three sections.** Go to the bottom one and press "A". This should open a window where you will select your wireless network. Select yours and test your xbox live connection. If all goes through, than you may click on edit settings to find that all of the data is automatically set in for you.
If you run into any more issues, Send me a message and i'm sure I can help. (Im gettin pretty good at this.)
Apr 03, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
