Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Hit power....lights come on....timer works....dryer don't run
  • budacar54 Oct 31, 2010
    Did not e-mail manual....took my money....thank's alot for ripping me off
    President:
  • 3,074 Answers
This might help if not just ask me again. Thank you Tim
http://www.doityourself.com/stry/repairdryer
Posted on Oct 16, 2010
  • Tim Whalen Nov 01, 2010
    Here is a website, I have no ideal of a manual but this will show you some things that may cause you problem and how to test them:
    http://www.partselect.com/dryer dryer-wont-start repair.htm
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer will not start but has power going to it timer works light comes on in drum just wont start when you hit the button
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Dryers
Has the door lock mechanism or the pin strike snapped these are located on the door and push into the appliance activating switches. Have a look around the door area .
Mar 20, 2010 | Whirlpool Dryers
The dryer will not run its cycle, the drum does not turn nor does the fan run. However, the timer counts down as though it is running a load. Door is tightly closed and temperature in room is not below 32...
I have a g e dryer modle # dblr333eeocc when i hit the start botton the dryer just hums. If i spin the drum by hand and then hit the door switch the dryer will work untill you open the door
Feb 17, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Lightning hit our house a month ago and the dryer was running. It stopped and now the start button won't stay engaged l We have to push the button to make it run and tape it in the run position,
your missing the voltage from the control panel timer to energize the relay to keep it energized after you push it to make it start,you need to trace this back to the control panel timer possibly thru a resistor that could have burned open due to power outage and probably replace
Nov 17, 2009 | Whirlpool LER7646E Dryer
The timer is running but the dryer will not come
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down
Oct 03, 2009 | Dryers
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
