Question about HP LaserJet P2015dn Printer
RE:HP P2015 Hi I installed HP P2015.The driver are installed okay.But cant print. And indicates UNKNOWN DEVICE ON THE DEVICE MANAGER. Warm regards Samuel
    Master:
  • 638 Answers
  1. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  2. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  3. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  4. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  5. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  6. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  7. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Posted on Jun 03, 2008
Cant find scanner driver or software for hp 3055
Hi
Use a Normal TWIN driver that appears in any software that allows you to scan or in Windows click on Start, Device and Printers, Select your HP3055 and SCAN
Dec 09, 2014 | HP LaserJet 3050 All-In-One Printer
I do not have the cd for installation of printer in my pc
You can get the drivers for the HP LaserJet P2015 from HERE.
Just select the Operating System from the list and download it.
All The Best.
With Regards:-
Subhankar Ghosh
Nov 17, 2010 | HP LaserJet P2015 Printer
I cant install my HP C4180 printer because the printer driver could not be saved because the source file could not be read???
1st You download Printer Driver. HP Photosmart Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 10, 2010 | HP Photosmart 4180 All-in-One Printer
Windows 7 cant see my hp 6110
1st You download Printer Driver. HP Office Jet Printer Driver After this install the Printer driver in the system.
May 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I cant find hpc20155.xml
This is direct from the HP website. some files were renamed... it works!
ISSUE: During the LaserJet P2015 Series USB installation, the following error message is displayed: 'hpc20155.xml' on HP LaserJet P2015 Series CD is needed SOLUTION: The HP LaserJet P2015 EWS driver on Microsoft Windows Update and Windows Market Place Web sites is newer than the driver that is included on the product CD that shipped with the printer. Because of this. the Microsoft Windows (Found New Hardware Wizard) will install the driver from the web. Some file names are inconsistent between driver version 1.0.0.12 and version 1.0.0.10, including the hpc20155.xml file, hence the attempt for the driver to search for the hpc20155.xml file will fail, and prompts the error message. To resolve this issue perform the following:
  1. Click the Browse button on the error message.
  2. Browse through the CD to Drivers -> windows 2000_XP .
  3. Select the file hppcp504.cab , and click OK .
  4. The error message "The Software that you are trying to install has not passed the windows Logo Test " appears. Click Continue Anyway .
  5. If the error message "hpc20155.xml on HP LaserJet P2015 Series CD is needed " appears again, follow steps 1-3.
  6. The required files are copied, and the driver is installed and ready to use.
If the issue still persists then perform the following in the order listed before trying to reinstall the software.
  1. Go to Start -> Control Panel -> System -> Hardware -> Windows Update.
  2. Set the option to Never search Windows Update for drivers .
NOTE: It is important to re-enable the Windows Update function after installing the printer software, otherwise the updates for all the other software on this computer will be blocked. After disabling Windows Update, complete the following steps. Be sure to reenable Windows update after installing the software:
  1. Disconnect the USB cable and remove the device listing from Device Manager
  2. Go to Start ->All programs ->HP ->P2015 ->Uninstall , "OR" Go to Add & Remove and check for the P2015 and uninstall .
  3. Then go to Printer & Faxes . Select the HP LJ P2015 icon and press the Delete button on the keyboard. After deleting the printer icon, go to File and Server properties . Go to Drivers tab and remove any P2015 drivers if listed.
  4. Also delete the following files/ folders C:\program files\HP\toolbox Fx or P2015 C:\documents & settings\app data\tool box Fx
  5. Run the scrubber.exe . Find this on the cd X:\utils\ccc\scrubber.exe & scrubber.ini NOTE: The Scrubber utility can also be downloaded from the web if the original installation CD is not available. However, it is only available as part of the full software installation package named hp_LJ_P2015_Full_Solution_AMWE.exe on hp.com . Once the files are extracted to a folder just open the util folder then the ccc folder and the scrubber.exe file will be visible.
  6. Paste these files at the following path and run the scrubber.exe C:\windows\system32\
  7. Empty the recycle bin
  8. Turn the printer back on.
  9. Now install the printer software again. Connect the communication cable to the PC and printer when prompted during the installation.
Sep 07, 2009 | Office Equipment & Supplies
In the device manager, Device manager unknown acpi
You would have to install the ATI chipset drivers , the same can be downloaded from the site below
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3292424
Thanks
Proton
Jul 04, 2009 | HP Compaq Presario SR2011WM PC Desktop
I could not print with hp laserjet p2015 usinh window vista
hi there,
Is the drivers of P2015 correctly installed on vista? If yes then you have to check your printer USB cable. Try to change it and see the result.
Good luck
Jun 24, 2009 | HP LaserJet P2015 Printer
Yellow ?
the yellow mark indicates that the drivers are not installed
Jul 23, 2008 | HP Business Notebook 530
Drivers
Go to HP's support site and download their auto detect program. I can't remember exactly what they call it. Then the site will detect your machine and give a list of drivers for it. Sometimes the bus and an unknown driver are in a utilities driver set. Just go down the list, you may have to download several before finding the right one, especially for the unknown since there is no way of knowing what type of device it is..
Jul 02, 2008 | Dell Inspiron™ E1505 PC Notebook
Drivers for HP presario 700 series
Dear Mohan,
1. Download HP Presario 700 series Laptop drivers at the following link:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&lang=en&dlc=en&product=95518
2. Right Click Undown device icon in Device Manager and choose Update driver from Online. It's automatically check the driver in Internet and Install.
HP LaserJet P2015dn Printer Logo
847 people viewed this question
Seeker5211
Seeker5211
