Question about Honeywell Heating & Cooling
My honeywell st699 programmer has gone blank thus it is not powering my heating or water.i have replaced fuse,checked fuse box,reset,all to no avail,any ideas please
SOURCE: keston c40 honeywel 9400c programmer
do a s plan plus and buy a poly plumb roomstat combined programer with built in relays as you require the relays to stop back feed! simple!
Posted on Jul 23, 2008
SOURCE: Honeywell Central Heating Timer ST699
In the end I bought another timer on sale/return. My heating didn't work with that one either, so my problem's not the timer but something else.
Posted on Aug 27, 2008
  • 17 Answers
SOURCE: replacing Honeywell heating progrmmer
yep the wires will hook up to the same designations, just write down what color was connected where. You will need to set the thermostat up for your particular situation...gas, electric, heat pump, ect. The installation maunel is very clear on this aspect so you should not have a problem.
Posted on Nov 14, 2008
  • 68 Answers
SOURCE: replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Posted on Dec 14, 2008
tborn6
  • 700 Answers
SOURCE: I am replacing my thermostat
needm to configure the thermostat to run only when the nit is callling. in the insrallation manuel there is instructions on how to do it.
Posted on Mar 26, 2009
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Can you replace a danfoss TP9 with a honeywell ST699
I believe the TP9 is a programmable thermostat.
While it appears the ST699 is a timer that connects to a thermostat.
So yes, they both control 230Volt boiler-and-pump. But there are differences.
Google search each item and include .pdf in search parameter to find product manual for each, and then compare wiring differences.
Nov 19, 2012 | Honeywell Hardware & Accessories
How do i remove the cover of my honeywell st699 programmer
switch of the power; use a small screwdrive to press down carefully into the three small slots (two at the top, one at bottom left) to release the plastic clips while easing the front panel towards you.
Sep 06, 2010 | Honeywell Electronic Programmable...
Hi I have a Honeywell st699 programmer for central heating and hot water. The only problem that we have is that we can not change the time on the clock. This means that we cannot set any programmes. Is it...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 17, 2010 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
T8411r1028 honeywell thermostat
Check in the heating unit itself for an automotive style fuse.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Replacing Honeywell heating progrmmer
Oct 30, 2008 | Honeywell Programmable Thermostat Heater
I have a honeywell ST699B controller for my central heating & water, i walked past it today and the light that indictes the water is on was illuminated. The water is set to come on once a day but not...
i have an st699 programmer its set to go on twice a day heating up but when the wife gets up after ive gone to work the timer is not at the correct time so no heating any ideas as new ones expensive to buy
Jun 25, 2008 | Heating & Cooling
Honeywell programmer gone dead
lift the face plate off and change the batteries
Jul 07, 2017 | Honeywell 2-way Oscillating Ceramic Heater
Heating & Cooling Logo
93 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
