Question about Kenmore 500 6953 Dryer
No heat where is the fuse located is there a diagram ?
    President:
  • 3,074 Answers
Check this site out it is the best:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Hope this helped Tim
Posted on Oct 16, 2010
Do not have onwers manual for 2008 f-250 super duty. I want fuse diagram
fuse for seat heater
Connie, Check attached links, 2nd. link tells what fuse/relay and location.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix heated seats in Ford f350 2003
one heated seat not working
2008 250 fuse for heated seat Google Search
Mar 30, 2016 | Seat Cars & Trucks
On a 1988 Mercury Grand M. I have a fuse on the fuse panel that is a 30 amp metal covered fuse. It is about 1/4 inch thick by about 1" by 1/2 inch it is located on the top of the panel. I have no fuse...
You may find the diagram on the link in a forum who's address is listed below:
http://www.fordforums.com/f102/fuse-chart-1988-grand-marquis-160848/
Please check if you can access it. As for the heating problem you will have to inspect the socket for corrosion or loose parts. You may also have to trace the wire for wiring issue. Other than that you may need to check the components using the fuse to check if it is overloaded. It may be weakening or assembly connected to it may be bad or is simply overworked.
Sep 14, 2011 | Mercury Grand Marquis Cars & Trucks
I think my rear window heating fuse on my 2007 Focus cc-2 has gone. Where is the fuse?
Terry, looking at a diagram for an SE the fuse will be a 40amp fuse located in the battery junction box located under the hood. I believe the fuse is #17.. Best of Luck to you.
Aug 19, 2011 | Ford Focus Cars & Trucks
I need to know which fuse is for the heated seats for my Chevy Tahoe which is a 2001 model. thank you
The fuse for the heated seats is located in one of the two fuse panels inside the vehicle. Below is a discription of the location of the fuse panel you need to find the fuse as well as a diagram of the fuse layout. The fuse that you want to check will be the fuse marked "HTD ST". This should be in your owners manual if you have one. If you do not and would like a copy, you can email me at csautomotivecars@att.net with your make, model and year and I will be happy to email you a copy. No worries, no cost for it. I hope this helps and good luck.
Jul 29, 2011 | 2001 Chevrolet Tahoe
My kenmore elec. dryer 67042 model wont get hot...I never recd a manual..need diagram to dis assemble and examine the unit! Can u help me find a diagram?
Make sure the unit is not plugged in when testing these fuses.You should also check the continuity on the heating element if all fuses check out as good.You may also need to check the main power at the terminal block and make sure you have 220 volts to the terminal block.These are all located on the rear of the dryer remove the back panel to get to them.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Mar 19, 2011 | Kenmore Dryers
My heat and air conditioner wont blow any air. Also the lighter wont work. I think a fuss may have blown however; dont know were the fuss panel is. HELP.
The fuse box is located on the leftside under the dash, i will see if i can send a diagram to help you locate it . the blower fuse is # 25 and the cig lighter is 33, heres a diagram of the fuse setup, hope this helps.johnjohn2_13.gif
Nov 07, 2010 | 1999 Volkswagen Passat
My whirl pool dryer does not dry?
coil never gets power usually a sign that you have a blown thermal fuse , small white 2in' fuse located behind rear panel, there should be a wire diagram behind the console, few screws acrosss the back
Oct 30, 2008 | Dryers
No heat in Maytag Electric Dryer
There should be a wiring diagram inside the operating console. Locate the thermal fuse and/or thermal cut-out and ensure they check good. They both should read close to a short if good. They are mounted adjacent to the heating element. If you have trouble locating the diagram and/or need further assistance isolating the problem, please post back with the dryer model number (located on the back of the console) and I will locate some diagrams to see if I can assist you further.
May 28, 2008 | Dryers
Kenmore 500 6953 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
