Question about Maytag Ovens
Maytag single oven Model CRE9800ACE will not heat.
  • jkrey1 Oct 20, 2010
    Thanks for your reply, and suggestions regarding a GAS oven that would not heat. My question was specifically in regarding to a MAYTAG ELECTRIC OVEN MODEL CRE9800ACE, Serial number 13003265hu. Please advise. Thank you.
    Genius:
  • 1,035 Answers
Hi. Checked if there are burnt spot in the bake element of the oven. If there are, then you need to replace the bake element. This is how bake element looked like.
Posted on Oct 20, 2010
    President:
  • 1,216 Answers
This pearl of wisdom shall guide your through the diagnosis and repair of your oven:
If you have a gas oven that's not firing, don't be ******** and automatically assume the valve is bad (hint: it's usually not). What else could it be? Ah, Grasshoppah, read and learn.
Maytag single oven Model CRE9800ACE - tn_hot-surface-ignsheet-big.jpgYou may even see the orange "glow plug" (called a hot surface ignitor) glowing orange and so assume that it's OK. But you would probably be wrong. Many $$ wrong. You gotsta measure the current drawn by the ignitor before you can say it's OK or not. The gas valve has a bi-metal that snaps open when a certain amount of current flows through it to heat it up. The ignitor is wired in series with the gas valve. As the ignitor ages, its resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. Consequently, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking. This service sheet illustrates the main players in the ignition system and how to test them.
tn_gas_range_components-big.jpgHere's another picture that shows the main components in a gas oven. The big thing to notice is the difference in current draw between the round and flat ignitors. Look, there's just no substitute for measuring the current draw--this is the gold standard for diagnosing gas oven ignition problems. I'll let you in a little secret, though: if the ignitor glows but the oven takes longer than three minutes to fire up then, 97.98745987% of the time, the problem is a bad ignitor. Here's another tip: if you buy the ignitor through this parts link and that doesn't fix it, you can return the ignitor for a refund. Who else but the Samurai will make you a deal like that?
I've talked to lots of shotgun parts-changers about this problem. These are guys who can't be bothered with the theory of operation. Besides, they already know everything anyway, so they just shoot from the hip and end up replacing a bunch of parts that were still good. They blew beaucoup bucks on a new valve and just can't understand why the oven still won't fire up. But now, you know why.
Posted on Oct 16, 2010
Maytag Gasline Oven - everything works fine - range and brolier start immediately yet oven clicks but does not heat anymore. Was working fine but no longer heats.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 18, 2011 | Maytag CWG3100A Gas Single Oven
Maytag 30" PGR571DBDQ stove. Oventook over 30 minutes to reach 350 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 13, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean"...
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Apr 09, 2010 | Maytag 30" Built-In Single Electric Wall...
My Maytag electric oven will not heat beyond a
Your temperature control has gone out and this is simple repair!!
Oct 20, 2009 | Maytag 30" Built-In Single Electric Wall...
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Why won't my Maytag electric oven heat past 210 degrees?
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
Apr 08, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Maytag gas oven takes long time to heat, sometimes not at all
sounds like a bad oven ignitor, part number 12400035 comes with all instructions on how to install
Dec 06, 2008 | Maytag CWG3100A Gas Single Oven
Maytag oven calibration
Maytag single built in oven model cwe9000bcb beeps intermittenly. Reset stops for about 1 minute. Two control panel boards replaced since 2002 with same problem. Can it be fixed?
Dec 18, 2007 | Maytag CWE4800A Electric Single Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
81 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
