Question about Sony Grand WEGA KF50SX300 50" Television
Trying to get it to work on HD
Hi - I have just purchased a HD DVD player and am trying to figure out how to get the TV to run on HD. The DVD player talks about progressive scanning. I have lost the manual for the TV.
Any suggestions?
Tks
Bob
  • 10,594 Answers
Please mention correct model of tv to help.
Posted on Jun 03, 2008
I can't get the DVD player to view dvd on tv
hi konni.
this is all i could find .
DVD player not working with TV By Charlotte Parker 25 Aug 2017
You've got your Sky Box, your TV, your DVD Player and your surround sound; you've also got your digi-box, your DVD recorder, Blu-Ray Player. With all that equipment, if something goes wrong it can be tricky to track down the issue. This article explains why your TV isn't playing DVDs and how to get it sorted out.
Figuring out the problem
Figuring out why your DVD Player isn't working with your TV is a process of elimination, so work through the steps below to figure out the cause of the problem.
The problem could be:
  • The connector cables/connections.
  • The DVD disc itself.
  • The DVD Player's optical reader (the lens which 'reads' the DVDs).
  • The TV.
Before doing anything, check all your connector cables. Make sure that all connections are in properly, and that the cables are in the right place.
One of the most important connections is the cable that runs between your TV and the DVD Player. If it isn't in place, then your TV can't read the information from the DVD Player and the film won't appear on your TV.
The DVD disc itself
Check for scratches, chips, smudges and any other marks. Test the disc isn't the problem by trying a different one in the player. If the new disc works, then the first one might need replacing.
The TVTry changing channels. Lots of TV's have a default channel specifically for DVD players. Have a look between the channels to see if the DVD menu appears.
On modern televisions, especially those connected to Digi-boxes or Sky Boxes, there's usually a 'Source' button on the remote control. Find it and go through until you reach the right setting for playing DVDs. To go back to watching normal TV channels after the DVD has finished, go back to the source button and change back to the original source.
That should be all you need to know to get your DVD player working with your TV
if none of above works then try putting a lens cleaner through it to try and clean the lens that reads the disc.
Nov 05, 2017 | Televison & Video
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
Dvd won't load
I too have a SpectronIQ PD 300-HD that came bundled with my 32" LCD tv (PLTV-3250) and have had the exact same problem. The only thing that worked for me was to totally unhook the DVD player from the tv (HDMI cables and everything) and unplug it from the power source for a minimum of 30 minutes to try to reset it to the factory defaults. The last time I tried this, however, it didn't work. I'm now having a problem with my TV as well - I just got my HD DVR from Dish Network and my picture keeps going from black screen to the blue "just turned on" screen, with the power light going from green to red. Then, suddenly the picture comes back, but sometimes the picture is "tiled", like the tiles news broadcasts use to hide someone's identity. I even have a Dish Network tech at my house RIGHT NOW who is having all kinds of problems figuring out what the problem is, but he thinks it's - GASP - the TV! Of course, since SpectronIQ went bankrupt and Shop NBC (the retailer the set was purchased from, as a GIFT, no less) has been absolutely USELESS, I have no idea what to do and am absolutely LOATH to purchase a new LCD tv. Does anyone know what can be done?
Aug 19, 2008 | Spectroniq PD-3000HD
I have a DVD player Panasonic DMR ES20D which is working OK but I have just been on the Amazon site to make DVD a purchase and the site has a warning in red reading " Warning this HD-DVD will not play...
Even though you have an HD TV, the DVD player is not HD-capable. You will have to upgrade to an HD set to use those discs. (You might consider that Sony's system, "Blu-Ray, is now the format winner in this case, and therefore try to find your disc selection in the Blu-Ray format.)...accordianman
Jul 20, 2008 | Panasonic Televison & Video
Connecting an a/v receiver to a Dish network receiver
DO you have manuals for all the units listed?
If not , try the Samsung consumer site.
It would take me quite a while to figure out your situation even with manuals and I have a business to run besides.
Also, ask some questions of Tech Support at Samsung..Let them KNOW how much you spent on their stuff.
God bless,
SF
Jul 07, 2008 | Televison & Video
Digital TV
right hdtv stands for high definitian tv witch basically means if you buy a hd dvd player or blueray then you can watch the films in really high quality alot better than normal dvd. The same if you had cable tv or sky you pay a fee for an hd converter then this lets you watch certain channels in high def. So it basically means that your telly is capable of using all the new hd equipment thats coming out like the playstation 3 can play high def dvd's as long as you buy the hd lead as you need this due to the fact that it sends more data to the telly their for giving alot better sound quality and alot better piture quality when watching hd dvd's.
At the moment their are only a few tv channels that are using hd at the moment but this will soon change.
So to watch hd dvd youll need an hd dvd player and to watch hd tv you need to contact your cable or sky people and ask them what you need to do to watch hd programmes. they will then upgrade your box and should send you an hd lead to plug into your telly from the sky or cable box.
Hope this is helpfull and easy to understand.
Hd is well worth having as the quality is amazing you wont believe it till you try it i was shocked as the detail and quality is mind blowing its like watching real life, it really is that good.
Let me know if you need further assistance ok
May 14, 2008 | Sylvania 6427TE 27" TV
Samsung LE26R51BD HDMI PROBLEM
Sounds to me like you need to change your input feed oin the settings menu of you TV to HDMI. If it doesn't work then you can either return the DVD player because using an HD DVD with a non HD capable TV is pointless, or you can upgrade to an HD TV.
Mar 15, 2008 | Samsung LN-R268W 26 in. HD-Ready LCD...
Connection for tv cable to hitachi 42" plasma Tv
there is no cable slot. the monitor is not a receiver. it has no tuner in it. it will need a signal from a tuner box. and that must be fed to the tv with an hdmi cable or a dvid cable for hd to work. see your manual for further information on cables. see your cable supplier for information on hd boxes available in your area. if you do not buy hd service, you will not get an hd signal. so you will see little difference from a non hd device. your dvd player may have hd capabilities, but will also need the same cable to deliver true hd signal.
the good news is that its fixable by using the right equipment.
good luck
mark
Dec 07, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sony Grand WEGA KF50SX300 50" Television Logo
62 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
