Question about Cuisinart DCC-2000
Basically my unit will not brew the coffee. The clock displays the time but I am unable to get the brew light to turn on. What sort of tests can I perform to determine the problem? Kirkl
  • 2 more comments
  • KIRK STAMP Oct 16, 2010
    I tried the decalcification process and I am not able to turn on the coffee maker. It does not run through since it does not turn on. My unit does not have a grind feature. Is there a board or thermocouple that I can check out?
    Kirk
    I tried the decalification process but my unit will not tunr on. I am unable to run any liquid through the coffee maker. Also I have no grind feature. It is just a coffee maker. Is there a thermo couple, heating element or board to check ?
    Kirk
    Correct. The timer is functioning. I am able to change the time and change the program time. I am not able to get the brew light to turn on or the program brew light to turn on.
    Kirk
  • KIRK STAMP Oct 17, 2010
    I checked the continuity of the heating element and it is okay. I smelled an burnt electrical odor. My coffee maker does not look like the one in thew illustration and I am not sure that I actually found the thermostat. There was a wire that lead into some shrink tubing and a wire coming out. A clip holds the tubbing next to the element. The continuity across that is okay also.
    Any other ideas?
    Kirk
  • 3,530 Answers
Try to decalcify first. It is possible that there has been a calcium build up.
To clean, fill the water reservoir to capacity with a mixture of 1/2 of white vinegar and 2/3 water. Press the Grind Off button, and turn the coffeemaker on by pressing the On button. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Posted on Oct 16, 2010
  • 3 more comments
  • Jose Cada
    Jose Cada Oct 16, 2010
    Let me just clarify, it is not turning on at all? No lights? What about the timer?
  • Jose Cada
    Thanks for the additional information. Let me get back to you in a few minutes.
  • Jose Cada
    The light is not turning on because the sensor does not detect any heat. You have to test the heating element and the thermostat.
    Click on this link to show you how to test these parts. You will need a screwdriver and a volt-ohm meter. Be careful, make sure to turn them machine off first.
    If your machine is still warranty, take it in for a service. Your safety is more important.
  • Jose Cada
    Jose Cada Oct 17, 2010
    Thank you. Okay, let me check back.
  • Jose Cada
    Kirk, this model DCC-2000 is very well known and wide spread design flaw. You might want to call Cuisinart to plead your case. Check this link.
I have a Mr. Coffee, Model JWX20 with no instructions. I would like to set it so that it will come on in the morning and brew coffee before I wake up. I can't find a manual. Does anyone know how...
Set the Clock: 1. Plug the power cord into a standard electrical outlet . The clock will flash on the control panel to indicate that the time has not been set yet. 2. Press and hold the HOUR and MINUTE buttons until you reach the current time. The AM or PM indicator will light a t the bottom of the display The clock is now set! NOTE: Pressing any button before setting the clock will cause the clock to start keeping time from 12:00 a.m. You must set the clock if you want to use the Delay Brew feature. To Set the Delay Brew Time: *While the display is in the clock mode, simply press the SET DELAY button and, while the DELAY BREW time is flashing, set the brew time by pressing the HOUR and MINUTE but tons. *The AM or PM indicator will light at the bottom of the clock display. *Within a few seconds the display will change to the current time. The Delay Brew Time is now set!
Jan 18, 2015 | Coffee Makers & Espresso Machines
Can't set clock. 12:00 keeps flashing
SETTING THE CLOCK AND DELAY BREW TIME
To Set the Clock:
1.
Plug the power cord into a standard electrical outlet. The clock
been set yet.
2.
the current time. The AM or PM indicator will light at the bottom
of the display (Figure 1).
NOTE:
Nov 01, 2014 | Mr. Coffee 10-Cup OptimalBrew Thermal...
All lights are blinking on coffee maker & unable to brew.
The cups only brew one mug at a time. Open and close the lid to check if that resets itself.
Otherwise, turn the machine off and on again to "reset" the function. Also check that there is enough water
Nov 12, 2013 | Keurig Coffee Makers & Espresso Machines
All I need is the manual to my Mr.Coffee Pot how to set the timer to Mr. Coffee GBX23.
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Aug 20, 2011 | Mr. Coffee GBX23
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
I have Mr Coffee APX33; I do not know how to set the coffeemaker to turn on automatically. I do not have the manual. Hope you can help. Thanks! Larry
First you have to make sure to set the clock for the correct current time:
Press down and hold the SET button. Then alternately press the UP and DOWN buttons (indicated by arrows), until you reach the current time, then release the SET button. (there is a PM indicator on screen but not an AM indicator - if you don't see the PM you are at AM)
To set the time for the brew to start in the future:
Press and release the MODE button once and the Delay Brew Clock picture will start flashing on the screen.
While the Clock picture is flashing - hold down the SET button while you use the UP and DOWN arrow buttons to set the desired brew time (you can hold down an arrow button to get there faster). Release the SET button and now that brew time is programmed. (After a few seconds the clock picture will disappear but the future brew time is programmed.)
To activate the delayed brew:
Press and release the MODE button once. The Clock picture will be flashing and the time shown will be the time that you previously set for the future brew). While the Clock picture is flashing - press and release the BREW button. The Clock picture will remain on steady. The BREW light will not come on until the time in the future that you have programmed.
Pretty confusing - but it does work. Just remember that if you see the Clock picture on steady - the machine will come on at the time you have set in.
If you want to use the machine earlier - while the Clock picture is steady - you just press the BREW button and it will brew.
If the Clock picture is steady but you want to cancel the automatic future brew - just press the BREW button twice. (This turns it on and then off and cancels the future brew).
I can send a copy of the manual if you like. Lennyg678@aol
Sep 17, 2010 | Mr. Coffee APX33 Coffee Maker
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
reach the current time. The PM indicator will light on the left
of the display.
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Pot keeps shutting off after coffee completely brewed.
This may be an electrical issue, but I would try holding in the on/off button for a few seconds and see if it still displays 2 hrs as the auto-off time. If 2 hrs does display correctly, unplug the unit for 16 minutes or longer - do not plug it back in a single second shy of 16 minutes. Then reset the clock and reprogram the auto-off Try one more time.
If that fails, it may be replacement time.
-Tha Mp3 Doctor
Nov 28, 2008 | Cuisinart DGB-500 Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
149 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
