Question about Insignia I-LC26Q1 Television
I turned on my insignia tv-picture, no volume. i don't know what button i hit but now all i have is fuzz, and a little message saying "NO SIGNAL." HELP!!!!
  • jmccarthy48 Oct 16, 2010
    my remote does not have a specific AV button
  • Insignia Master
  • 11,800 Answers
No signal means exactly what the message says - no signal is received. If you use an external receiver then you must have probably pushed one of the channels buttons, moving the source to the Antenna/TV.
All you have to do to fix that is to select again the correct AV source - push the AV button on the remote until the image returns.
Posted on Oct 16, 2010
  • Azrael SRL Oct 16, 2010
    It's the button that allows you to select different sources : it's labeled tv/av, or Source, or it has an arrow pointing in a circle.
My tv is a hitachi hd ready flat screen plasma tv and i am using universal remote control The tv was working fine until i swtiched it off and hit one of the buttons on the remote - possibily the av...
What are u using for a signal source? Cable, Satellite, Over the air? My best guess is that you hit a wrong button such as the "source" button and the remote doesn't know what device you are wanting to opperate. Press volume up then down and see what light lights up?
If it is other than "TV" then you probably have the wrong device selected... Hope this helps... Sincerely HDTV GURU JAY
Mar 15, 2011 | Hitachi Televison & Video
Insignia 26"LCD TV "No Signal"
Your description pretty much narrows it down to tuner failure. I have had experience with Insignia products so not surprised.
Mar 03, 2017 | Insignia LCDTV26 26 in. Television
How do I reset Lamp in PT40LC12 with out a remote
After turning on the TV and viewing the message to "reset the lamp" I became frustrated and attempted to shut the TV off by pushing the power button. A message popped up saying "Do you want turn the TV off Yes / no.
I toggled down using the volume/Channel button on the tv to say no. The next thing i know...The TV picture came on and the la,p was reset!!! I really don not know how this happened! but it worked! Thanks for your assistance. Now, i can program a remote!
Oct 23, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
May 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
BLACK BOX PROBLEMS: Insignia TV/DVD combo
The black box is caused by the Closed Caption option of the tv. Go into the menu and turn it off.
Jul 18, 2008 | Insignia IS-LCDTV32 32 in. Television
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
No Signal
You will have changed the video/audio input, on your tv, it should be an input button on remote. The signal will either be on AV1, AV2, AV3 Component or HDMI.
Jan 24, 2007 | Polaroid FLM-3225 32 in. LCD Television
Weird error?
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Oct 23, 2006 | SanDisk Sansa e260 MP3 Player
Insignia I-LC26Q1 Television Logo
43 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
