Question about Garden
What kind of oil to use in a cub cadet LT2180 rear end
  • 7,482 Answers
Gear Oil...90-120w
Please rate me
Posted on Oct 16, 2010
How do i get the pto clutch off of a cub cadet lt2180
you need a impack gun to get the nut off the cluctch it will come right off
Sep 17, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
Cub cadet troubleshooting Have a 2005 cub cadet 5254. Starts fine and stays running,however when put into gear it won't move. Any clues as to what it could be.
can't say for sure but it might just be a belt broke or out
of hydrolic fluid depends of type of transmission.
Oct 06, 2013 | Garden
LT2180 engine will not charge battery. New coils installed last year due to rodent damage. Regulator??
The LT2180 has a voltage regulator, good chance it may be that. When you say it will not charge battery, did you check the output? Put a voltmeter on the battery not running and check voltage. Then start engine and check again. If the voltage does not go up then there is a problem. Would not want to see you replace a voltage regulator when the battery may not be holding a charge.
Jun 15, 2011 | Cub Cadet Garden
What are the propper oils and lubes for the model 127 cub cadet?
Well, personally, i use a normal engine oil; what ever your preferance. i use pennzoil. for the engine, the weight that they call for at cub cadet in those days is winter-5w20-summer 10w30. they call for a low ash oil, you can get it at any cub cadet or internation harvestor dealership. the rear end, if its a hydro stat takes hy-tran fluid, also sold at the dealer. you cant use anything else in a hydro, theyre real touchy. if its gear differential, any 80-100w gear oil will work. hopefully this helps, ive been dealing with old cub cadets for a close to 20 or more years. good luck!
Aug 14, 2010 | Cub Cadet Model 18611862 Parts Operators...
How do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
