Question about Casio Exilim Pro EX-F1 Digital Camera
What microphone do you recommend for the casio exilim
3 Suggested Answers
SOURCE: casio exilim Z75 lens problem
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
The movement of the lens is motor driven. When you turn the camera on, the lens moves. The error 12, error 14, and error 22 refer to control stages in the lens movement ( I think error 22 means the lens won't retract). The lens housing and gear mechanism in this camera is plastic. If there is dust, sand, or debris around the lens housing, it may bind the lens when it trys to extend or retract. By banging it, you might work the gears loose or dislodge whatever is binding the lens (same with the "canned air" blowing out the dust). We've purchased a bunch of these cameras for our electricians in the field. Several have come back with this problem. I've taken the case off, and torn the lens assembly apart, only to find the plastic gears have been "buggered up". It's an inexpensive camera. Try to clean around the lens, give it a few slaps, push/pull the lens.... but failing this fix, buy a new one. Good Luck!
regards iversh
if you felt i've spent my time for u... a very helpful rating is appreciated...
Posted on Aug 18, 2009
  • 102366 Answers
SOURCE: will not upload to imac 20 Casio EXILIM Digital Camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Posted on Apr 30, 2014
My Casio EX-H30 video sound not coming please if some one knows about it
-try to simultaneosly press the up directional arrow while playing videos
-up and down arrow controls volume during video playback in your camera
tip: avoid blocking the microphone on top of the camera during recording. (small pinhole on top of the camera)
Jun 05, 2011 | Casio EXILIM EX-H30 Digital Camera
Which battery should i buy for the Casio Exilim camera EX-Z60
NP 20 Battery is always recommended. If you wish you could buy it from :-
http://cgi.ebay.com/NP-20-Battery-CASIO-EXILIM-EX-Z60-Digital-Camera-/170477986015?pt=Batteries_Chargers
Good Luck!!
Thanks!!
Aug 17, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio ex-s10 microphone isnt working
I have the same problem. Have you found out what to do about it?
Feb 02, 2010 | Casio Exilim EX-S500 Digital Camera
Have casio Exilim camera model Ex-600 require
I have a casio exilim 8.1mp ex-z80 green digital camera. The casing is no longer presentable. Do you know where is the CASIO SERVICE CENTER here in the philippines, specially in davao city...
Oct 04, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Video function
An easier way to do this is to just press the right-hand button on the round wheel surrounding the set button. This allows you to scroll through all the various record modes: Snapshot, Bestshot, Video, & Microphone.
Apr 02, 2009 | Casio Exilim EX-Z40 Digital Camera
2GB memory card but only 1GB available
That is one of the problems we have seen because it isn't a model that casio recommends using with the camera. Toshiba, Panasonic, and Sandisc are the only models that they have tested and know work so that's what they recommend you use.
Sep 09, 2008 | Casio Exilim Pro EX-P600 Digital Camera
Casio camera card error
It could be either a brand that is not supported or there could be something wrong with your card. Casio only recommends Sandisk, Toshiba and Panasonic memory cards. Try one of those brands and make sure you format it with your camera before trying to save pics to it.
Nov 17, 2007 | Casio Exilim EX-S600 Digital Camera
SYSTEM ERROR Casio Exilim EX-S3 R!!! (barely used)
don't know of any at home fix for a system error. Tech support always recommends that something like that be sent in.
Aug 13, 2006 | Casio Exilim EX-S3 Digital Camera
Casio Exilim Pro EX-F1 Digital Camera Logo
83 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
