Question about Sony Handycam DCR-TRV250E Digital Camcorder
Cannot play or record st comes up with eject tape
When i want to play or record it will beep and tell me to take the tape out.
so annoying as i have a new baby due n 3 weeks :o(
MINE HAD THE SAME PROBLEM, I RESEARCHED IT AND FOUND ON YOUTUBE...ALL I DID WAS TOOK A Q-TIP AND PRESSED ON THE LITTLE BLACK RUBBER ROLLER INSIDE OF WHERE THE TAPE GOES ON THE CAMERA. YOULL KNOW WHAT IM TALKIN ABOUT ONCE YOU LOOK IN THERE. I GUESS MINE JUST NEEDED PUSHED DOWN FURTHER OR SOMETHING. JUST TRY IT, DONT PRESS TOO FIRMLY THOUGH.
Posted on Aug 10, 2009
  • 10,594 Answers
Camera has Mechanical/ Electornic problem (Reel signal missing) and needs qualified technician to fix it.
Posted on Jun 03, 2008
Constant ejecting
This is already an issue with the hardware. There is a rubber bond inside the cassette that is no longer intact and needs to be replaced. Possible cause by repetition of single and old cassette tape and improper tape position.
Apr 06, 2010 | Video Cameras
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Jun 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Cannot play tape nor record on tape
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Oct 08, 2007 | Samsung VP-D361 Mini DV Digital Camcorder
Camera won't record a certain tape
either the tape is sticky or is hard to take the reel. that's why it's beeping.
Aug 07, 2007 | Canon ZR45MC Mini DV Digital Camcorder
Sony Handycam DCR-TRV250E Digital Camcorder Logo
215 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
