Will following software work with my airport card on my mac 10.6? /trac.kismac-ng.org/
  • mwiseman96 Oct 16, 2010
    can not see actual download link?many thanks.
  • 11,800 Answers
Yes, it will support it, it says just that in the second paragraph: All of the internal AirPort hardware is supported for scanning. But the support isn't quite perfect - in FAQ it says this: Apple introduced a new public AirPort API in 10.6. Support for this new API is in the process of being implemented, though it appears that the API does not respond very reliably and might behave well or not at all. Or something in between, or switch randomly.
If you want 100% reliability you should wait the next version, otherwise you can install it, just that it might need multiple attempts to do just one sniffing. In that case you should get the latest beta
http://trac.kismac-ng.org/changeset/331
Posted on Oct 16, 2010
My powerbook g4 no longer recognize my builted in airport, have no airport now. The only way to make my g4 work in hook an either net cable to my g4 into my router. Makes my laptop very stationary, what...
What I would suggest is reseating the airport card as it may be the card has come loose or the cable is not connected properly. The following support page on the apple website will tell you how to do it.
support.apple.com/kb/HT2617
Failing that you will probably have to buy an new airport card or a wireless usb adaptor. You should be able to pick one up from ebay fairly cheaply.
Hope this helps.
Apr 17, 2011 | Apple PowerBook G4 Mac Notebook
My kismac opens in safari,how do I get it to open in its own page,ie kismac file edit channel ect? from this I can select file preferences.
Hi.
KisMAC is ordinarily listed in Applications, like any other installed app.
If KisMAC does not appear in applications, then reinstall the program following the directions in the provided links (you may need to install XCode and SVN client separately).
To open preferences:
a. Open KisMAC.app from Applications
b. Click KisMAC->Preferences
You can also open preferences by pressing COMMAND + COMMA hotkeys at any time.
If that does not work, reinstall Kismak following directions below:
KisMAC Compilation & Installation HowTo
How to instal KisMAC in Pasv mode (useful).
If you still get troubles there may be a problem with MacOS, try uninstalling KisMAC, updating Mac OS, then install KisMAC again.
Oct 17, 2010 | Computers & Internet
Airport card disconnected
There is no Macbook pro G4 (macbook pro are using intel chips) please clarify
Jan 19, 2010 | Apple PowerBook G4 Mac Notebook
Which USB network cards are compatible with Kismac
Broadcom chipsets are the best for this type of work
Aug 10, 2009 | Apple 13 MacBook Notebook Computer ...
Airport connection working, but only certain
you might have a proxy set in safari settings.
follow these steps to remove it.
good luck
Jun 17, 2009 | Apple safari
Reply: What wireless card does your macbook have?
AirPort Card Information:
Wireless Card Type: AirPort Extreme (0x168C, 0x86)
Wireless Card Locale: USA
Wireless Card Firmware Version: 1.4.8.0
this info can be found in apple/about this mac/more info/system profile/airport card
Jan 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Airport connection - G5 Powerbook
Yes better get a new wireless card if there's a airport that can be connected via USB that will be better..
Good luck....
Jul 21, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Airport hardware is not recognized
I say it'd be more likely that the airport card shifted in the socket. I could be wrong but take a look. I'm not sure if it's true on the 12" models, but on all the others, there is a cover in the battery compartment that hides the airport. Take it out and put it back in. My 17" powerbook took a 4ft drop to the asphalt late last year and it came out with only a few small scratches. You might also try swapping the airport card with another one just to verify if the slot is good.
May 31, 2008 | Apple PowerBook G4 Mac Notebook
MAC CLAMSHELL LAPTOP
Yes, you can use the ethernet 10/100baseT connector for high speed, the 56K modem for dial up or an optional Airport card for wireless
Jan 22, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
Open Questions:
Get Data Recovery Backup Online Data Recovery Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jun 18, 2018 | VIA Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
