Question about HP Color LaserJet 2600n Printer
Hp Color Laserjet 2600n occasional printing errors
My Hp Color Laserjet 2600n does not print at all. In the past I've had the same problem.In the past I re-installed the printer driver a few times and it worked. Now it does absolutely nothing. There's no problem with the cabling, I've already checked that.
  • 2 more comments
  • t1aflightops Jun 26, 2008
    my hp 2600n is correctly set up and installed, and all the toners are full.. but it wont come on. no lights light up. and when i push the on button, i hear everything moving inside..but then nothing happens... please help!!
  • Namrocoh Jul 10, 2008
    My HP Color Laserjet 2600n worked flawlessly till the first year was up. I never turned it off I never did anything but put paper in the tray and replace toner cartridges. So far only black has needed to be changed. I have plenty of toner. I get a error message stating I may be on a VPN thus causing my printer to to "talk with"my computer. After much hunting I find that VPN stands for virtual private network. I have the printer plugged in via an earthlink connection to my Link-sys wireless router, and I access my printer wirelessly via that link sys router. It was working fine and then for no apparent reason if fails to print. Now it seems I have a $300 tempermental paper weight. Until now I swore by HP......now all I do is swear @ my HP. Help....I know it's got to be something really simple. I can manually print test pages and such but it will not print on command from my dell inspiron 1300 laptop. Namroch@aol.com
  • zna2212 Jul 13, 2008
    Not printing. No lights on but can see lights inside printer, so know it is getting power. Tried uninstall/re-install. Message came up to plug in the USB cable and power on printer. I thought maybe bad USB cord so tried another one that I knew worked. No luck. Still dead.
  • Cnythia Miller May 11, 2010
    Does the printer point to lpt1 instead of usb connection?
    Master:
  • 638 Answers
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Posted on Jun 04, 2008
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Our HP Color LaserJet printer has a 10.10000 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0001 = Cyan print cartridge
try this:
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the cartridge.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the print...like it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
Network printer problem
try the usb cable if the computer can print print test that would be the network is wrong ip address that declare you on printer
Feb 04, 2010 | HP Color LaserJet 2600n Printer
Can't print in SAP R3 to HP LJ2600n
Supported HP Printer: HP Color LaserJet 2600n printer
(Host-Based)
Recommended PCL5 Device Type: SAPWIN
- requires Server-based printing via SAPSprint or Frontend Printing via SAPgui
Supported SAP Release: See SAP Note # 8928
Dec 11, 2009 | HP Color LaserJet 2600n Printer
HP Color laserjet 2600 only black print is commong
It a problem with printer fusing assembly. so you can checked it from service center.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
No color on the laserJet 2600n
On the control panel (PRINTER) , Print settinGS, there must be a option to activate/desactivate print without color, only using black cartridge, you should desactivate this option and the printer will print on color.
If you couldn´t locate this option, restore the original settings on the control panel (printer) the error must be resoloved!
sorry for my english!
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Hp color laserjet 2600n ''black print down form its orignal place''
an allignment need to perform on printer with proper placement.
Nov 27, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
94 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
