Question about Midtronics Measuring Tools & Sensors
I have a midtronics micro 420. every battery i test comes back bad if i set the cca at the right number. if i put the cca at 100 most come back good. example: i have a battery that calls for 450 cca. i set the test at 450. it comes back at 100cca on a brand new battery. so i tested other ones and the same thing. any idea on what it could ber
  • 2 more comments
  • airjordan127 Oct 16, 2010
    as a short do u think the computer board is bad because midtronics said a new board is 189 which i dont think is to bad of a price
  • airjordan127 Oct 17, 2010
    so what do i do to fix it
  • 12,061 Answers
You have a faulty Voltage Divider resistor/Comparator IC in the unit, this is the part that actually is used to set and calibrate the unit.
They use proprietary parts, so your only shot at repair is to return the unit to Midtronics and ask them to repair it. Repair costs are very reasonable.
You need to contact them and inquire as to what to do. Website link below.
www.midtronics.com/
Posted on Oct 18, 2010
  • 10,319 Answers
The reostat inside beneath the dial is at fault
Posted on Oct 17, 2010
  • 10,865 Answers
Your tester has a short in it. Return it if you can. Otherwise get an estimate on a repair or a replacement. Joe
Posted on Oct 16, 2010
Snow mobile wont start
Sounds like a bad contact between the Battery, reversed polarity but more than likely, your Battery is Bad. There is a difference between Volts and Amperage (CCA). Have the Battery Tested and you will more than likely find out your Battery is Bad. These Small Batteries do not last long (Warranty is 6 months).
Dec 22, 2013 | Arctic Cat 2006 Panther 660
05 Chrysler Pacifica engine bucking , engine light comes on, battery light comes on. But battery is fully charged and alternator is working. When the battery comes out, it seems like the computer re
The Battery CCA Rating is to turn over the starter
CCA--Cold Cranking Amps
That is at zero degrees
Total cranking amps is at 32 degrees
The car runs off the alternator
It puts out over 14 volts
The 12 volt battery is 6 cells @1.2 v each = 13.2 v
You need 12.6 volts to test a car or you charge it first
You need over 13 volts to charge a battery,thus the alternator
The only other job the battery has is a stabilizer in the electrical
circuit
So you need to have the charging system diagnosed as the
various light you have on should be off when engine first starts
Dec 13, 2012 | 2005 Chrysler Pacifica
I have a 96 cadillac deville with charging problems. It starts up with 13-14 volts but while driving it fluctuates up and down, eventually working its way down to low voltage. on occasion it may go as low...
That sounds like the tensioner wheel is not holding the serpentine belt tight enough to get full contact with the alternator. The spring on the tensioner arm can get weak. The whole arm and wheel is probably under $100.
They might sell the spring separately for very cheap.
Mar 18, 2017 | 1996 Cadillac DeVille
How do you check the battery status?
Check battery voltage using Volt meter=> it should be about 12.6 to 13.8 vdc.
Pull the battery out... checking the deforming at the case ..such as "swelling"... if yes .. replace the battery.
Replacement battery is about 10-20 dollars on e-bay (watch for shipping charge and size. and terminal connection sizes )
The average life of battery on UPS is about 5-7-10 years wi)th UPS plugged in (Charging
One I had my local Autozone checked my 12 VDC -8 AH ... ask them to set CCA at about 100 AMP...
for 12 VDC -14 AH ask them to set CCA about 200 AMP.
For a 12 VDC -75 AH (group 24) they set the load on their tester at about 700-900 CCA.
You can also buy a manual battery load test at Harror freigt tool for about $20 US dollars (On sale)
Feb 18, 2011 | APC Back-UPS ES 350 - UPS ( external ) -...
My 95 corolla will not start. When I put the charger on the battery it says the battery is fully chared. When I put the charger on quick start the starter clicks and grinds but doesn't pull in to turn the...
OK, if the battery has 12.5 volts or so, the charger will say it's fully charged. But, the real test is to load test it and check for CCA which should be like 550 CCA and above for most cars.
You could purchase a new battery from Walmart, an auto parts store, or Sears, and before you purchase it, have them test the old one to see if it is bad or good.
Once, you have a known good battery, then you can try it in the car. If it just clicks and grinds but doesn't turn the engine over, then you know you have a bad starter in the car, which will have to be changed.
Aug 17, 2010 | Toyota Corolla Cars & Trucks
Battery test proper voltage, new alternator test normal to low voltage,have trouble starting at times. while driving amp gauge shows varying readings of 14 to 10
If you test battery with a load test it will probably fail. Battery is bad. Also have alternator tested. Go to any parts store, even walmart they all test for free. I would put my money on bad battery. Cells getting weak.
Jul 17, 2009 | GMC Safari Cars & Trucks
2003 Mountaineer won't start, battery is good.
CHECK BATTERY CABLES AND FOR CORROSION,A BAD GROUND OR BAD CONNECTION WILL CREATE ENOUGH RESISTANCE TO PREVENT STARTER TO CRANK OVER ENGINE. IF BATTERY HAS 12V DOESN'T MEAN IT'S GOOD,IT COULD HAVE ON 100 CCA'S, NOT ENOUGH.
Jul 13, 2009 | 2007 Mercury Mountaineer
I have a 06 pt cruiser the battery light came on
there is a tsb on that in the dealerships i belive there is a flsh for the computer to fix this problem i have been a mechanic at a chrysler dealership for 9 years now and that is a pretty common problem
Apr 01, 2009 | 2001 Chrysler PT Cruiser
Measuring Tools & Sensors Logo
699 people viewed this question
Top Midtronics Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Midtronics Measuring Tool and Sensor Expert? Answer questions, earn points and help others
