Question about Vintage Keeper 250 Plus Wine Cellar
My chillr plus (900) struggles to hold 56 degrees. The wine cellar is well insulated.
  • 32 Answers
SOURCE: Cuisinart Private Reserve cwc-900 wine cellar stopped cooling
I haven't seen the unit you refer too but it sounds like many others that I have seen. The white stuff is heat transfer compound as used on CPU heat sinks, DO NOT WIPE IT CLEAN, if you have then it will need replacing. Check the fan is running at full speed to cool the heat sink that the plate is attached to. If there is no fan then there isnt much else that can be wrong with it apart from the control circuit, but that seems to be working as you say the plate gets hot.
Posted on Mar 19, 2008
  • 7 Answers
SOURCE: Fan doesn't work on oster wine cellar
First question, do you have power to the unit and the cooling fan is not working? If this is the problem then sounds like one of the two fuses in back panel has burnt out.
Posted on Feb 23, 2009
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
  • 288 Answers
SOURCE: My kool space wine cellar is not holding temperature
has the cellar ever worked right in your home? These small refrigeration units basically move heat from a conditioned space to another space that is not objectionable such as your home where your central air system then moves the btu's. This being said, the cellar has a ventilation system that must pull in room air and push out the box air. these vents must be clean and clear of obstrucions to ensure proper performance by the equipment
Posted on Nov 27, 2009
SOURCE: Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Posted on Aug 16, 2010
How to tell the year of a koolspace wine cooler
That will always depend on the Manufacture of your Koolspace Wine Cooler. If Koolspace keeps record's they will ask you for your serial number. It does appear you have an eliete model and brand name so I would think they are well ahead of the game.
Fax: 403-283-6111
Calgary Phone: (403) 283-7575
Toll-Free: (877) 283-7575
Design/Construction Inquiry: Click Here
Wine Cellar Services Inquiry: Click Here
Accounting Inquiry: Click Here
Cellar Coordinator Inquiry: Click Here
Gallery
If you have warranty issues with your cooling unit (ChillR or Vintage Keeper Nuvo), please contact the manufacturer directly at www.wineracking.com or 1-888-274-8813
We have set up our Calgary space to introduce you to the most stylish and sensible storage and lifestyle accessories for the discerning wine-enthusiast.
Please feel free to drop by our showroom at any time during regular business hours. If you prefer we can arrange practically any time that is convenient for you.
10:00 am - 5:00 pm : Mon - Fri
Saturdays by appointment only
If this was a Whirlpool question I could find it myself with model and serial If helpful please rate this solution, Thank You, Sea Beeze
Nov 24, 2011 | Refrigerators
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
I have a Koolspace 250 nuvo in my garage. It is having a hard time cooling in the summer. It is holding 68-70 degree F when set to 52 degrees. Can I make it insulated or put a fan above it to help? Can it...
You should contact Koolpace regarding this issue. They can be reached at:
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 04, 2011 | Vintage Keeper Koolspace Wine Cellar
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Vintage Keeper 250 Plus Wine Cellar Logo
61 people viewed this question
Top Vintage Keeper Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
