Question about Freezers
I have recently obtained a second hand Beko NZ701 freezer and wonder what the 3 lights indicate (red green red)? Also there is a switch that I don't know the purposde of. Is this a strightforward power switch or a fast freeze function?
SOURCE: BEKO TZS490
AS A FRIDGE ENGINEER I HAVE COME ACROSS THIS PROBLEM BEFORE IT COULD BE A LOSS OF REFRIGERANT ALTHOUGH THIS WOULD STEADILY WORSEN IN USE,MORE LIKELY THERE IS A BLOCKAGE IN THE SYSTEM STOPPING THE REFRIGERANT REACHING ALL THE PIPEWORK THE CHEAPER FREEZERS USE THE SHELFS AS PART OF THE FREEZING SYSTEM.
THE ONLY SOLUTION IS A COMPRESSOR CHANGE AND REGAS (COSTLY IF NOT COVERED BY WARRANTY/GUARANTEE ETC)
IF FREEZER IS MORE THAN 5 YRS OLD BEST TO SCRAP IT UNFORTUNATELY..
Posted on Dec 19, 2007
jaylex
  • 417 Answers
SOURCE: servis fridge freezer mo330al lights
Hi there
  • Green = Ready (Power ON)
  • Amber = Super Speed Freeze
  • Red = Warning overheating or fault.
Hope this helps
Thanks J
Posted on Feb 16, 2008
  • 1462 Answers
SOURCE: warning alarm and light
it will do that till temp is reached
Posted on Oct 20, 2008
  • 9 Answers
SOURCE: Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Posted on Apr 23, 2009
garing
  • 998 Answers
SOURCE: Green indicator light not working on Beko freezer
should pry out
thumbs up
Posted on Aug 17, 2009
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Hi. I have just aquired an "IGNIS" chest freezer, model AFE 460/IG, class T. On the bottom right hand side of the freezer ther is a dial (from 0 to 3) which can be altered using a screwdriver...
Pretty sure that the slide is for winter and summer operation, you are rite, the 3 position is the cold level and the 3 lights (Yellow, Red, Green). the Yellow indicates a caution,"" not at temp or faulty""the Red indicates the unit is active and the Green indicates at temp and operating correct. This unit is old and not much information is available however I hope from my experience, that will help you, any further problems call Russ on 08 95230552.
DONT FORGET TO VOTE, I SUPPLY MY TIME FOR FREE TO HELP. RUSS
Mar 02, 2011 | Freezers
Red light on, tripping the fuse box
Need to know if it's tripping a breaker or an RCD.
sound like an earth fault and tripping the protection.
you need a qualified professional.
Mar 27, 2010 | Freezers
I don't know what the lights mean on my Beko chest freezer. Have just found it defrosted and want to make sure the defrost is off. It is switched on at the mains. What lights should be on? I've lost the...
two reds and green are the auto max freeze on indecators the reds go off one at a time when unit drops to safe temp mode.also means unit needs defrosting manually when too much ice is present.
Feb 03, 2010 | Freezers
Philips Freezer
Jun 24, 2008 | Freezers
Servis fridge freezer mo330al lights
Hi there
Hope this helps
Thanks J
Jan 04, 2008 | Freezers
What are the lights?
I cannot find any manual or information on the 3 lights. I would assume that the green light means everything is OK, the red means current problem, and the amber means manual defrost is due. Sorry, this is the best I can do. Later.
Aug 24, 2006 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
325 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
