Question about Microsoft Xbox 360 Console
How do I connect my xbox using a hdmi cable - Microsoft Xbox 360 Console
  • 104 Answers
Step 1 Plug hdmi cabel into back of Xbox and TV
Step 2 Turn on your Xbox
Step 3 Go to your settings
step 4 Go to video or visual
step 5 Look for anything like output or somthing like that
step 6 Change output to hdmi
step 7 It should test the connection so change the input on your TV from av or whatever you were using to hdmi
Step 8 Rate this solution and enjoy hd
Any problems question or concers just let me know
Posted on Oct 16, 2010
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How do I get sound from my Xbox to my monitor via a hdmi lead - DVD lead
As far as I know, the DVI cable can't send sound, so if you could use a only-HDMI cable or SCART cable, that should give you both picture and sound.
Nov 11, 2012 | Microsoft Xbox 360 Console
How do i connect a xbox360 to the system
You can usually connect the Xbox 360 to a sound system using an optical cable, which connects to a port on the Xbox's video cable. If you use a HDMI lead with your Xbox then you will need one of these adapters to give you the optical audio port:
http://www.amazon.co.uk/XBOX-HDMI-CABLE-OPTICAL-ADAPTER/dp/B003Q958RW/ref=pd_cp_vg_h__0
I'm sure you can find something similar on Amazon for your location.
Best of luck!
Mar 09, 2011 | Philips HTS3400/37 System
Connect my xbox on reicever
If your xbox has HDMI connector then you HDMI cable to connect it to the receiver and another HDMI cable to connect receiver to the TV. Receiver should support both video and audio over HDMI.
If your xbox doesn't have HDMI, connect the video directly to your TV using whatever connector/cable is available (in terms of quality from best to worst: HDMI, component, s-video/scart, composite).
Then connect audio to the receiver via optical spdif cable.
Jan 29, 2010 | Yamaha RX-V463 Receiver
The x4 wants me to run the digital audio through the component cable of my xbox but i am using an hdmi cable, what gives? the picture and audio r better with hdmi, can i run the thr ir transmiter through...
If your TV has a Toslink optical digital output, then you can run that to the digital input on the X4. That would probably work best.
Also, Microsoft sells an "audio cable" with their HDMI Cable set. http://www.xbox.com/en-IE/hardware/x/xbox360hdmiavcable/
That connects to the A/V port, right under the HDMI port on the Xbox rear panel. You can get that cable for less than the Microsoft price. Use Google to search for "Xbox hdmi audio cable" or "Xbox audio dongle".
Jul 21, 2009 | Microsoft Turtle Beach X4 Dolby Digital...
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Hdmi cable connected nothing happens
Are you making sure to change the input settings on your TV/Home Theater System? You may have to instruct the receiving device to use the HDMI input.
Also, are you have to make sure that the settings in the XBOX are set to use the HDMI output instead.
I honestly don't own an X360 so I couldn't tell you for sure. This is a general principle one must keep in mind when using electronics in general, really.
But I did take some time to track down an instructional overview of using an HDMI connection. It's actually on MS's XBOX site. Perhaps this will help you?
Click HERE to see this site.
Also there has been the occasional report of the HDMI cable coming with the XBOX 360 Elite being nonfunctional. You may consider testing with a different HDMI cable.
Remember to make sure you are checking the OUTPUT on the X360...and the INPUTS on your HDTV. Or your Home Theater system...if that's where you're connecting it. Remember that you may need a second HDMI cable to go FROM your home theater system to your HDTV if that is the case.
Let us know what happens!
Cyryl
Dec 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
