Question about LG DLE2532W Electric Dryer
No heat for model DLE2532 - LG DLE2532W Electric Dryer
  • LG Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
How to connect a new dryer plug
Helo,
Yes you can reconnect it to the original place and everything will be fine...
Heatman101
Feb 24, 2010 | LG DLE2532W Electric Dryer
Loud humming sound while drying, need instructions on disassembly to properly diagnose
Disconnect power to dryer. Open door, remove phillips screw from 4 and 8 O'Clock positions, close door. Use putty knife (preferably a plastic one to prevent scratching) to push in the two clips holding the top to the front panel, then swing the top back, revealing the phillips screws holding the front panel onto the body of the dryer. Remove them and un-hook door switch and drum light connections, allowing total removal of dryer front panel. Remove 4 phillips head screws retaining front drum support and lift it up just a bit to remove it. Reach back under drum to the left side to release belt, allowing drum to come out of dryer.
Jan 29, 2010 | LG DLE2532W Electric Dryer
Dryer taking too long
Make sure the lint filter is clean and that the exhaust duct and outlet are not clogged. If the duct is clear check to see if air is being blown through. If not then the blower fan may be disconnected from the motor shaft.
Jan 17, 2010 | LG DLE2532W Electric Dryer
No heat
Assuming it is tumbling, check out the heater element. This is the most common problem for this type of dryer.
Jan 02, 2010 | LG DLE2532W Electric Dryer
WE HAVE HAD THE LG DLE2532W DRYER JUST OVER THREE YEARS. RECENTLY, WE HAD TO REPLACE THE DRUM BECAUSE IT HAD A CRACK IN IT. NOW THE REPLACEMNT DRUM (FOUR MONTHS OLD) HAS A CRACK IN IT AND THE DRYER IS NOT...
Here's one place you can order a new drum. However, if the drum has cracked twice in four months you need to find out if there's something else with the dryer that's making the drum crack. You also need to think if you're doing something like putting shoes in there or something that's stressful on the dryer.
Nov 01, 2009 | LG DLE2532W Electric Dryer
Why isn't my dry grtting hot?
Check the house circuit breaker pair for the dryer--push off, then on. If no help, measure the voltage at the two slanted slots in the power socket. It should measure ~230 volts AC. If zero, either one of the breaker pair is bad, or there is an open wire between the socket and the breaker panel. If reads 230 volts, the problem is within the dryer--usually the heating element. The drum must be removed to get at the element.
Oct 11, 2009 | LG DLE2532W Electric Dryer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
97 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
