Question about Kenmore 92812 / 92814 Electric Kitchen Range
My kenmore oven just stoped working. I changed the element but that was not the problem. The lights come on with the preheat but does not heat. (790.9532201) VF33325675
  • kpro222 Oct 16, 2010
    Thank you.
    The model no. is 7909532201. It might be different for the newer models. It is about 7 yrs. old. we do not have a ohms reader. is there any other way to check? also, is it very expensive to replace? I appreciate the e-mail.
    President:
  • 1,891 Answers
The only control for the oven is the clock and some model's do have a hi limit on the backk of oven . if the last thing you did when using oven was the cleaning cycle then i belive the hi limit may have opened the power line . couldn't find a wiring dig for model 970-9532201 .. but do ck the wiring on the back of range and i think you will see the disc type thermo . hope this helped mm and thanks for using fix-ya .. ps ck you model # and get back if more help is needed mm
Posted on Oct 17, 2010
  • Kenmore Master
  • 19,396 Answers
Hi.
Problem is likely the temperature sensor probe, located inside the oven cavity. A test can be done reading Ohms at the probe terminals and jumping the probe.
Model number was incomplete. I think this is your model, please check the number. Here parts and diagrams, please ensure number is correct: 79095322301.
Posted on Oct 16, 2010
  • Ginko
    Ginko Oct 16, 2010
    Hi.
    The sensor can also be tested by jumping it, if not done properly in that way you can blow the element. This operation should be done by a technician or by an experienced DIYer.
    Part is also less than $10.
    The model did not match any of the models in my databases. The range should be same as one of this.
    Just use the schematics, and call telling the number to verify before buying.
    Part is nr 37 in this diagram, inside cavity.
    Here part: Probe
Oven takes forever to preheat. Only the bottom oven element comes on during preheat.
Try checking the heating elements on the top might have come loose
Apr 22, 2016 | Ovens
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Jan 08, 2018 | Whirlpool Kitchen Ranges
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Preheat issue with a new kenmore electric range
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Jun 07, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kenmore 92812 / 92814 Electric Kitchen Range Logo
188 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
