Question about IBM Computers & Internet
My compter always shuts' down within 5-30 mintues
    Brigadier General:
  • 8,909 Answers
Clean the cooling fan with a vacuum cleaner CAREFULLY!
This sounds like when the CPU has been working for a short while, it gets overheated and stops working. Check for fluff and dust in the cooling air vent.
Posted on Oct 16, 2010
HP DV2500 Battery charged to 100% but dies within minutes
Your battery is done. Batteries only have a useful life, and after that you have to replace them because they will not recharge or hold a charge.
May 30, 2012 | Office Equipment & Supplies
Tv problem
Check its horizontal output section circuit for any loose solder terminals. Resolder all suspected solder terminals by applying little more fresh solder. Replace the horizontal output transistor. If this transistor have some leak, it will overheat within minutes will shut down the picture.
May 26, 2012 | RCA 27F530T 27" TV
I have macbook pro version 10.6.6 and i have reliance netconnect usb connection. but i am having problem after few mins using internet my laptop shows a message that i need to shut down the compter and...
I too have macbook pro version 10.6.6 and i have reliance netconnect usb connection. but i am having problem after few mins using internet my laptop shows a message that i need to shut down the compter and restart again. its happening all the time.
please advise what i need to fix this problem. i think some drivers compatible with macbook pro
Apr 17, 2011 | Computers & Internet
Engine shuts off going down the road restarts after a few mintues and no problems for a few more days
Fuel pump in gas tank bad. Also make sure the gas filter isn't on there ,for several years.
Apr 15, 2010 | 1995 Buick Regal
Switch oven on within 3 mintues the fuses blow main fuse box
I suspect the fan oven element has failed, this is located at the rear of the inner oven compartment behind a removeable cover
It is probably breaking down as the element gets hotter.
Feb 28, 2010 | Neff B1421 Electric Single Oven
Oven temperature does not get hot enough.
Hi, It sounds like the ignitor might be getting weak and opening the gas valve conditantly. Try setting a temperature and watch to see the ignitor glow. The flame should ignite within 30-45 seconds. If the flame ignites to heat rith away, it should get up to temp before shutting down.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Jun 24, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Computer shuts off automatically everytime
Usually this happens because of overheating your best bet would be to take it apart and see if there is a fan problem. Most likely need to replace a fan inside/upgrade as it may not be working properly. Also make sure your bents are all clean of dust and debris. Use computer air to clean it out.
Thank you,
Lee
Apr 27, 2009 | Dell Studio 15 Laptop
Compter won't reoot
Try booting with using the Last Known Good Configuration option.
See if you can get into windows that way.
Let me know if that doesn't work and we talk about salvaging you data.
Regards
Dec 20, 2008 | Averatec 3200 Notebook
Comupter shut on and off
Please remember to always note Computer specifications and Operating system details when you post a problem and to explain your problem in more detail.
Apr 16, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
66 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
