Question about Minolta DiALTA Di620 All-In-One Laser Printer
I have minolta di520 machine. For computer connectivity i purchase fairy device. when i connect with printer cable, then the machine process, but with cross cable machine does not work.
  • Minolta Master
  • 6,161 Answers
Check the web site for the Firery also check the operator manual for the copier Print controller I believe that model came with one. Pi 5500 something like that. Very old Minolta machine, now Konicaminolta, try this web site for
Self Help Product Support Konica Minolta Business Solutions Inc
Posted on Mar 02, 2015
  • 300 Answers
SOURCE: Minolta Di520
From the service manual
These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and
communications. For remedial action change the board, check for cable connections, and turn OFF
and ON the power.
C133B - Check cables for proper connection and, if they are okay, change the finisher cpu board.
Hope this helps!
Posted on May 19, 2008
SOURCE: minolta di520
es el pote fraSCO DEL TONER
AT THE TONER WHERE IS
Posted on Sep 30, 2008
  • 1294 Answers
SOURCE: I REPLACED MY TONER COLLECTION Minolta d520
Press Utility key and press in this order STOP-0-STOP-0-0-1,select COUNTER windows,select waste toner windows: for SET press C(cancel 10 keys pad) introduction 320000; for Counter press C.press Exit too quit,back the basic menu.
Posted on Jul 30, 2009
  • 1294 Answers
COF 34 is a code to refer T/C recovery failure as detected by ATDC sensor.Change ATDC sensor,if problem persist,change developer(starter) and then run F8 and F5 function operation in that order.Developer change every 1000000 copies.
  • 351 Answers
SOURCE: what printer cable is needed. I purchased a Konica
If you recently bought it. It will need a standard USB cable available at almost any store including most super markets.
Posted on Mar 04, 2011
I need fairy connectivity cable
What is a FAIRY Connectivity cable? what type of end connectors?
Sep 08, 2013 | Minolta DiALTA Di520 Laser Printer
Minolta DiALTA Di520 Laser Printer code 13f1
Replace the print head the device that houses the machine LASER, or the J or A printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Jan 22, 2013 | Minolta DiALTA Di520 Laser Printer
My copier minolta 520 was not working error code c13f1
sir/mam Replace the print head the device that houses the machine LASER, or the "J" or "A" printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
Nov 18, 2012 | Minolta DiALTA Di520 Laser Printer
13f1 code problem
PRINTHEAD which houses the machine LASER is bad or the control board that control is bad. But number one is Check all connections between the both of them
Minolta di520 error code C0990
Large capacity draw bottom draw lift problem. gear might be bad or the cable snapped.
Aug 13, 2012 | Minolta DiALTA Di520 Laser Printer
Hi, I have a printer Minolta DiAlta Di520, when i turn on the power swich apear the message : codice errore c-13f0 Can you help me? Thanks!!!
Print head is bad that is what houses the machine LASER or the J or A board is bad. check all connections to the print head first I would replace that first if you can find one, then go with the boards if you can find them.
Oct 06, 2010 | Minolta DiALTA Di520 Laser Printer
I have a Minolta Dialta Di520 that shows an error code of c-0110. The machine was working fine before being moved. It may have been bumped along the way. Also, the FN3 finishing unit is not connected at...
Image Transfer/Paper Separator Wire Cleaning Motor M8's failure
to turn · Faulty Transfer/Separator Wire Cleaning Home Position Sensor PC17
would be in the middle section, under the drum assy that has to very fine wires a device that looks like it would clean them, will the cleaning device is jammed or the motor that run it is jammed burned out, or the control board is bad.
Aug 01, 2010 | Minolta DiALTA Di520 Laser Printer
Minolta Di520 - Request of Refund
I understand now, unfortunately i didn't do the live chat nor am i paid for helping, just like you i came acrossed this site and thought i'd help a few people by donating some spare time.
I am however an IT engineer and am familiar with your copier, as i suggested earlier reset the tech rep switch and see if it clears your error.
I suggest you contact the site for your refund.
Regards
May 19, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Di520
and ON the power.
Hope this helps!
Minolta di520
C10XX - C14XX these malfunctions code are concerned with faulty simptoms as they relate to software,hardware and communications.For remedial action change the board,check the cable connections and turn OFF and ON the power.80% you have be change a PWB-B board(in the right side, up by pass cover),20% touch the PWB-B reset switch.
Nov 15, 2007 | Minolta DiALTA Di520 Laser Printer
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
