Question about Panasonic CT-36SX12 36" TV
I have 36" Panasonic CT-36SX12 TAU series. I had it repaired less than 3 years ago .and the same problem happened again As soon as turned the TV off it wouldn't turn back on .I was told this was the transformer? or power supply. The service call cost me over 400 dollars and i wanted to know if this was something could attempt on my own please help because the TV works great and don't want to junk it
    Brigadier General:
  • 8,909 Answers
I would check the remote control by taking it out of the room first. If that is not the problem, it is likely to be a dry joint in the power supply that is "arcing" and causing this problem.
Re soldering the heavy components on the power supply board may fix it.
WATCH OUT FOR CHARGED UP CAPACITORS - THEY ARE LETHAL WHEN CHARGED!
Posted on Oct 16, 2010
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
Manif. year?
If you are talking about the panasonic ct36sx12cf mine was manufatured on july 2002
Jul 27, 2008 | Panasonic CT-36SX12 36" TV
TV DOESNT TURN ON ,I SWITCH PLUGS ,I TRIED TO TURN THE TV ON FROM THE TELEVISION ,CAN YOU PLEASE HELP.
Possible blown fuse or worse. If you attempt to change the fuse use the same amps that is in it.
Mar 09, 2008 | Panasonic CT-36SX12 36" TV
Checking the 6.3a slo-blow fuse
if you open your tv , you have to put back the board, there are 2  clips
one on left other in the right that keep the board to the case of tv( you have to disconnect  the cable AC before open the tv)
you can see the fuse easely ( if  i remember good there is only one
fuse about near the switch on /off
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Tv will not turn on
This set has a common problem with th main fuse opening for no other apparent reason... One of the few exceptions to my corner-stone statement that a fuse is never the cause only a symptom..
Don't replace it though with the same type grade, use a 6.3a slo-blow gma type - available at Radio Shack... Try that and if everything works you're back in business.. If not we nee to find a cause...
Bill
PANASONIC CT-36SX12 IT FLASHED ON, TURNED OFF, AND NOW DOESN'T WORK AT ALL
If you're lucky, the main fuse just opened up. It takes a 6.3 Amp slow blow type. Otherwise, it could be a defective voltage regulator and related parts in the power supply I would guess.
Feb 11, 2007 | Panasonic CT-36SX12 36" TV
Panasonic CT-36SX12 36" TV Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
