Question about Microsoft Windows XP Home Edition for PC
I am not getting any sound in my computer. the plug is connected.
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reginout to scan for errors.
Posted on Oct 19, 2010
19LVWk monitor has no sound, connected to Acer Computer. Computer does not have DVI connection, MONITOR DOES. How can I get sound from the monitor speakers?
There should be an audio plug(headphone jack) located next to VGA plug on the monitor.You will need an audio plug running from the Monitor to the computer audio plug...that will give you sound :)
Jan 14, 2016 | Acer Computers & Internet
No sound out of labtec lcs 1020 speakers how to plug in
On a desktop you plug them into a jack located on your sound card (varies by card model) . Laptops use the headphone jack to connect external speakers.
Feb 17, 2015 | Labtec Lcs 1020 Computer Speakers In Box
How can i get sound on my computer from Sceptre flatscreen tv
If your Sceptre TV has audio output connections (often RCA connectors), you need an adapter cable with RCA plugs on one end and a miniature stereo plug on the other to connect to lhe LINE IN input of your computer's sound card
Aug 11, 2013 | Sceptre X37sv-Naga 37 in. LCD Television
I have a 32" LG
Hello Undernet01,
Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
Simples as pies.
BElectric
Dec 26, 2010 | Computers & Internet
I am getting a lot of distortion feedback when I connect my computer to the mixer but the feedback only starts when the computer is connected to an electrical outlet. I have plugged the computer to a...
Sounds like a ground problem. Try to hook a ground strap or wire from the case of the computers power supply to the ground of the mixer. If it still has noise, try to touch the ground to the bracket of the computers sound card. Most likely, the computer uses a three prong adaptor and the mixer does not. Outlet grounds have voltages which bleed off from motors and other devices, which could cause the 60hz noise. If your mixer has a three prong plug do not plug your computer and mixer in separate outlets with separate grounds or you could fry your system. If you still have problems use a three to two prong adaptor and attach an isolated ground wire on the adaptor for the computer.
Jun 25, 2010 | Gem Sound CDM-150 Mixer
No Sound
where do you have the audio outs plugged into? The front or rear ones on the computer...also, have you had an onboard sound chip or a sound card?
Feb 12, 2010 | Princeton Digital VL1716 17" LCD Monitor
NO SOUND IN MY AMD SEMPRON 2500 COMPUTER
if it was working at your friends youve probably plugged the cable into the wrong connection, is there a sound card in the machine or is it onboard sound? when you plug the spekaers into the pc it goes to the green connector
Jul 06, 2009 | AMD Sempron XP 2800, Processor - OEM...
Speakers connected to the flat panel won't work
Don't Connect them to the Monitor Directly.
It will Be easier for you to Connect them TO THE SOUND CARD (back of computer).
Apr 20, 2009 | Dell ADA745 Computer Speakers
I I get no sound from tv after hooking up computer
If you mean you've connected your computer to a VGA connector on the TV so you can use the TV as a monitor, not getting sound would be normal. The VGA input on the TV is video only. Any sounds the computer produces would still come only from the speakers you have connected to the computer. There isn't any problem that needs to be corrected.
If I'm not understanding your request, please post a follow-up comment and I'll try to help you further.
Mar 26, 2009 | Sharp LC37SH20U 37 in. LCD Television
No sound from p5k3 motherboard
have you connected to the motherboard with correct plug(generally green in for audio out)try with another of speaker if the problem persists than you onboard sound card is having problem
May 15, 2008 | ASUS Computers & Internet
Microsoft Windows XP Home Edition for PC Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
