Question about Nintendo 64 Console
I have an n64, and i've got the cable with the red yellow and white connectors, but, my tv doesn't have that connection on the back it only has scart so i have tried using a scart block but it doesnt even seem like its sending any signal. any helpp????
  • 30 Answers
You might want to get a new tv..
Posted on Oct 16, 2010
Vcr/dvd player and nintendo 64
you N64 should have the cable with yellow/red/white connections(RCA) Those should plug into the VCR ports that say Input. Then run that to your TV through the screw on Coax cable.
Nov 25, 2013 | Nintendo 64 Console
I dont know how to set it up
- First you need a rather old TV, like maybe before 2002, if you have one. Because on newer TVs N64 graphics are terrible !
- Once you have your TV, check to see if you have two cables with your 64 (if you don't something is missing !). One shaped like a little box on one end and an electrical plug on the other : you hook up the little box to your N64 and plug the device in the nearest power socket. The other cable has a a strange black and rectangular input that hook up in your N64 and 3 sockets that are red, yellow and white. Connect the latter on your TV by finding the same sockets with the same colours !
- Connect your controller to the console (it's the round-ish sockets in front of it)
- insert your game
- THEN turn on your console. Don't turn it on unless everything hooked up !
(if it doesn't work you may want to try the famous turn-off-the-console-blow-into-the-cartridge-put-it-back-and-try-turning-your-N64-again trick !)
Good luck ! :)
May 28, 2011 | Nintendo 64 Console
In my dorm room I have a N64, which works when I hooked it up. However it wont play in color it's only in black and white which is extremely annoying. I have a Sony Bravia. How do I fix this without...
You have more than likely connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables, COMPOSITE only uses one (the yellow plug). If you connect only one video cable to any of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check the connections on the rear of the TV and make sure you have not connected to a socket marked "COMPONENT", "Pr" "Pb" or "Y". If you are certain the cable is correctly connected, please try another cable.
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV. I will then be able to assist you further.
Regards,
BElectric
Jan 10, 2011 | Televison & Video
How do you connect the dvd player to tv ?
What kind of connection does the TV and DVD have? If it has reg cable you would put the coax cable coming off of the cable box to the in line on the DVD player and then connect another coax cable to the TV. If you have the 3 RCA connectors 1 white 1 red and 1 yellow you would connect it to an input in the back of the tv and follow the colors red to red white to white and yellow to yellow. Let me know if you need more help
Nov 10, 2010 | Insignia Televison & Video
Having problem with the connection of n64 to my LCD tv i have tried all the yellow,red,white but still no respond please help
Your LCD TV is probably HD and you may be plugging the RCA (Red/Yellow/White) cables in the HD slots. make sure you are plugging them into the standard input slots.
Dec 23, 2009 | Nintendo 64 Console
Can't not get our Nintendo 64 to work on our new Bravia TV
The Nintendo 64 sends out a signal that can only be properly decoded by old CRT TV's
Those Bravia TV's are the God's TV's even if they did work on it I wouldn't recommend it because it would most definitely eventually ruin the life span of your TV.
But to answer your Question the Cables should be plugged into AV1 which is the Red White and Yellow Connections
Nov 22, 2009 | Nintendo 64 Console
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
How to connect satellite radio?
No you don`t need HDMI cableing, and do not use the blue, green, red, this is for video 1080i, if your Samsung doesn`t support more than one audio input ( the red and white RCA female plug audio inputs) get a multi tap or a piggy back plug, this will allow you to have 4 inputs into 2 inputs, think of it like an extention cord, one plug into an outlet yielding 3 inlets.
Jan 27, 2009 | Samsung Audio Players & Recorders
N64 has static and audio noise
If its got what looks like a cable jack plug, its an RF Cable. As is, if those get kinked up badly enough, the copper inside of them can become damages, which can affect the way it sends the signal to the tv from the N64. Those cables can be picked up from local game stores. my suggestion though, is if you have the connectors, go with the Red,Yellow,White setup, Red and White are the sound cables, and the Yellow is your video. Better sound from it.
Oct 29, 2008 | Nintendo 64 Console
Nintendo 64 Console Logo
121 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
