Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I rebuilt this carb and it is geeting way to much fuel do you have a parts brake down and assembly instructions? The carb # is WT324
    Brigadier General:
  • 4,088 Answers
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to other brands as well. Hope this helps!
Posted on Oct 16, 2010
Rebuilt carb & replaced fuel lines-fuel filter,saw started.ran last nite now today it wont start
If you put the pump on the carb and then the gasket, then cover, you assembled it wrong and the pump is letting gas just run out of the tank when the engine is off.
Jan 21, 2014 | Poulan Garden
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
HAVE WALBRO CARB WT324 WHEN PRIMING FLOODS THE CARB NO FUEL EXITS THE FUEL VENT HOSE ANY HELP
There are two connections on the carb, one is connected to the suction side of the primer bulb, the other to the fuel pick up pipe in the tank, the idea is the primer pulls fuel from the carb, into the bulb and back into the tank, if the pipes to and from the primer are fitted round the wrong way it will try to push fuel into the carb and make it flood, so check the suction side of the primer is connected to the carb, and the tressure side is back to the tank.
Mar 13, 2012 | Garden
My Poulan 2025 Chainsaw fuel hoses have broke down and fell apart. I have new fuel line but do not know the hose routing. All I found in the tank was pieces of hose and the filter. Only one hole coming out...
Check out epartsreplacement.com and there is a video on there you can watch that talks about fuel line replacement. It is a very helpful video Tom. Good luck
Aug 07, 2011 | Poulan Pro Chain Saw 46cc 20"
I have 1988 chev c1500 V8 5.7. Truck turns over but will not stay running. I put fuel in the carb & it fires rite up but then quits. I took it to a shop & they replaced fuel pump, fuel screen, fuel...
The only thing left is the carb, Have it rebuilt, sounds like a needle valve or the float is sticking. Check the choke, make sure it's open first before having it rebuilt
Jul 16, 2009 | 1988 Chevrolet Silverado 2500
I have a chainsaw carb problem
clean out the two gas hoses with a pipecleaner then check replace the in-tank fuel filter if the carb still does not recieve gas your fuel float in the carbretor is not rising to let in the gas this will require disassembly of the WT324 carbretor
Apr 28, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2150 fuel line routing wt324 carb
the large hose from the tank goes to the suction side of the primer bulb. The large line from the out put side of the bulb goes to the bottom inlet of the carb.
the small line goes from the top outlet tube on the carb back into the tank near the primer bulb.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 2150 w/ walbro wt324 carb fuel line reassembly
the fule line that comes from the filter/ pick up will go straight to the nipple usualy the one closest to the middle of the carby.
the other hose comes from the carby to the in or **** side( punp it you can feel it)of the primer and then goes to the tank that is the return/ prime, nothing is conected to it in the tank. if you have the carby one the wrong way around it will not prime. just swap them over..
Nov 24, 2008 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
135 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
