Question about Kenmore 22622 Top Load Washer
Spins intermittinally? - Kenmore 22622 Top Load Washer
  • Shirley Osmond Oct 16, 2010
    I have ruled out this solution to the problem since the switch activates the agitator no problem. The washer will spin , but sometimes I have give a spin by hand.
MY KLH E12DB POWERS UP. WORKS INTERMITTINLY, AND WILL ALWAYS POWER UP BUT NO SOUND
I HAVE SAME PROBLEM. CAN YOU CHECK RESISTORS R42 and R49. Its on the middle circuit board. I need color code
Aug 07, 2011 | Audio Players & Recorders
Won't start
Check if there is spark, eventually replace spark plugs.
Check air intake and air filter.
Check fuel filter and check that the fuel pump is fine, that there is pressure and pump is not noisy.
Sep 30, 2008 | 1989 Honda Prelude
DSC warning displayed-- intermittin, runs fine but 3000 rpm limiter is annoying
could be anything from a tail light bulb out to a engine sensor ,take it to a jag dealer
Jul 28, 2010 | 2003 Jaguar X-Type
Engin ignition fuse blowing on 1999 dodge neon intermittinly when starting
check the coil for cracks also check the igniton module for shorts and the ignition wire for breaks or shorts to ground
Jan 22, 2010 | 1991 Dodge Dakota
Fuel low light comes on and gauge gose to e, but gose off after time then comes on intermittinly
sending unit inside the gas tank. I would highly recommend to replace the fuel pump at the same time.
Dec 30, 2009 | 1999 Chevrolet Silverado 1500
Heater fan words intermittinly
If your talking bout your blower fan. There maybe a short in the motor. Easy job to replace.
Aug 20, 2009 | 2004 Chevrolet Impala
SD-P403 PROJECTION MONITER RECEIVER
Most likely the switch is bad. But it could also be the relay that the switch controls... if your mechanically inclined, get back with me.
Jeff
Nov 28, 2007 | Pioneer PRO-200 60" Rear Projection...
Kenmore 22622 Top Load Washer Logo
Sal DeAngelo
fordexpert
Mike Carew
